dormador
what is the write setting for the power in routerboard..
Fri Feb 05, 2010 1:44 pm
Hi all
am using many different mini pci ...
am using manual setting for the power like this
1Mbps:26,2Mbps:26,5.5Mbps:26,11Mbps:26,6Mbps:25
9Mbps:25,12Mbps:25,18Mbps:25,24Mbps:25,
36Mbps:24,48Mbps:22,54Mbps:18
its good setting or not ?
its work from 2 week only ...but i dont know if it is good setting or not .
thanks
SurferTim
Re: what is the write setting for the power in routerboard..
Fri Feb 05, 2010 1:52 pm
If you are using different types of cards, the settings would probably work with a 500mw card, but if you try those settings with a lower power card like the R52, it will fail.
dormador
Fri Feb 05, 2010 2:16 pm
Thanks SurferTim
but i read here if i put 17 that mean 26 dbi !!
am using 433 + 411 version 3.23
i dont know if its write or wrong when i but 26dbm my card yes 500MW ....
SurferTim
Fri Feb 05, 2010 2:20 pm
Thanks SurferTim
I presume a Ubiquiti model. They are known for the power setting offset. Last time I checked, their high power cards (model SR2) had a 10db offset. 17db in the power setting would be 27db at the radio.
normis
Fri Feb 05, 2010 2:22 pm
default will work correctly with the offset! just use default for ALL your cards, including the UBNT cards
SurferTim
Fri Feb 05, 2010 2:27 pm
Hi normis! That is a good idea, but not always practical, or in some of my setups, not always legal. I turn the power down, not up. Most of my setups need more power than an R52, but not the max power of an R52H.
normis
Fri Feb 05, 2010 2:28 pm
if you can't use default, you must mind the offset that UBNT manual specifies.
dormador
Fri Feb 05, 2010 4:00 pm
thanks normis for your comment .. but when i put the power manual i has no interference my mode (B&G) i don't know why that's happen ...but that really happen with me...
one more thing i have one mini pci ((AR5006X 802.11abg )) when i put it default its give me the same result like my old manual setting ...
SurferTim
Fri Feb 05, 2010 6:39 pm
You are also changing the wireless setting "tx-power-mode", correct? In the CLI, you don't see this setting unless you use "print advanced".
I agree with normis for most situations. If you can use the default settings, I recommend doing so.
Users browsing this forum: MSN [Bot] and 61 guests
