MUM Europe 2020
GolemPL
RouterOS 4.6 and Virtual AP problem
Fri Mar 12, 2010 2:23 pm
Hello.
I found out that 4.6 version crashes winbox while using virtual ap features. Winbox simply closing window, that makes unable to manage virtialap by winbox. It worked fine at 4.5.
Any fixes ?
normis
Re: RouterOS 4.6 and Virtual AP problem
Fri Mar 12, 2010 3:19 pm
Yes, we know about this, next version will have fix.
angboontiong
Fri Mar 12, 2010 6:27 pm
Normis...
Since we well knew the mikrotik nowadays is very weak on the 11N support, any action plan on it?
some time, some forum friend was suspect that, it's the Mikrotik senior engineer already jump to the ubt???
normis
Mon Mar 15, 2010 11:43 am
that's not funny :)
802.11n itself is difficult, not that we have specific universal problems. Look at the 802.11n forum threads. After multiple complaints, people end up getting forum advice that fixes their links.
We are working on many major wireless improvements right now, it's not so easy, so we can't deliver yet.
pcglobelb
Mon Mar 15, 2010 12:10 pm
this is weird since im running v 4.6 and facing no problem with virtual ap
normis
Mon Mar 15, 2010 12:11 pm
you probably use console? this is winbox related issue.
pcglobelb
Mon Mar 15, 2010 12:15 pm
this is why i found it weird normis.... i use winbox :)
normis
Mon Mar 15, 2010 12:16 pm
you are lucky :)
Users browsing this forum: Google [Bot], server8 and 20 guests
