pikpik
Bonding via vpls
Tue Mar 23, 2010 12:02 pm
Is this possible ?
gringoZ
Re: Bonding via vpls
Tue Mar 23, 2010 12:27 pm
I think that yes. I try but without success... I dont know how to set up ldp for second parallel link :(
pikpik
Tue Mar 23, 2010 12:33 pm
mee to :P
mrz
Tue Mar 23, 2010 1:30 pm
You need two traffic engineering tunnels with static path, one tunnel over each link.
http://wiki.mikrotik.com/wiki/Manual:TE_Tunnels
-headstrong-
Tue Mar 23, 2010 2:02 pm
How do you make the VPLS's go over different Traffic Engineered tunnels?...Is 2x loopback IP's required? Or do you use the TE tunnel IP end points for the VPLS end points?
mrz
Tue Mar 23, 2010 4:02 pm
Traffic is forwarded onto TE tunnel automatically, if remote endpoint of VPLS pseudowire is the same as TE tunnel endpoint.
MichelePietravalle
Trainer
Trainer
Sat Mar 27, 2010 1:39 pm
and, if i will set 2 TE, VPLS uses only one or both?
thanks,
Michele Pietravalle
-headstrong-
Sat May 01, 2010 10:24 pm
How does a single router have 2x remote endpoints? Do I need 2 IP's in the same lobridge?
Users browsing this forum: No registered users and 33 guests
