AndreaN
Nstreme have serious problem with 802.11n
Wed Apr 28, 2010 12:21 am
I made several tests, I tried many links at all distances, and each time the same problem. Link falls for extended data loss if the band is saturated or not polled for too long. It 'a bug?? Please help us.
Ibersystems
Re: Nstreme have serious problem with 802.11n
Wed Apr 28, 2010 2:22 pm
In the wireless certification I think I heared that it's not possible to use nstreme with N.
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
colebert
Wed Apr 28, 2010 9:05 pm
I and many other people here use nstreme and 802.11n together without problem.
Amateurs built the Ark.
Professionals built the Titanic.
Ibersystems
Thu Apr 29, 2010 12:00 am
Not recommended, sorry, it must work as unexpected.
Martín
AndreaN
Thu Apr 29, 2010 12:48 am
yes it seems to work, try to make a bandwidth test in tcp mode,the link will crash.
colebert
Thu Apr 29, 2010 2:17 am
I don't know what to tell you guys. It and 802.11n together work great for me and I recommend it to everyone. This forum is filled with these sort of success stories.
ste
Thu Apr 29, 2010 8:20 am
I see this behavior in lab with 2 devices near to each other.
Reducing power solved the issue.
kolorasta
Fri Jul 16, 2010 8:03 pm
thank you... reducing power worked fine for me too..
angboontiong
Sat Jul 17, 2010 4:34 am
To make it work fine, the signal strength have within which level?
and all of you guy tested in the clean channel environment?
have you test in the very interference area?
kolorasta
Sat Jul 17, 2010 8:38 pm
in my case
one side: rb411ah, r5h, 24dbi ant
other side: rb433, r5h, 24dbi ant
ros 4.10 @ both sides
clean channel
with "default" tx power... link went down when i did a bandwith test
i setted tx power @ 20db... everything is ok now. i will test later @21db, @22db and so on to see which is the breaking point.
sorry 4 my poor english
Users browsing this forum: No registered users and 17 guests
