MUM Europe 2020
jspool
Rocket Dish Question
Sun Jun 06, 2010 7:56 pm
I am looking to put up a new ptp with 411's sr71-15's and my question is if you can use the rocket dish antenna's and achieve good results. They are so much cheaper but are they any good?
Im going to be using mimo, and I don't plan on doing dual nstreme
Anyone tried using the rocket dish with a tik? what was your results? what coax did you use?
Thanks,
Josh
Belyivulk
Re: Rocket Dish Question
Sun Jun 06, 2010 11:19 pm
We have on several links - we put domes on them though (wind loading)
To date we have been really impressed with them - using LMR200 flyleads about 80cm long, SMA to N-male (straight to pigtail on enclosure) we have a 46km link with R52N (power turned down to 16db) and we get -71 / -73 on that link - passing 28mbit TCP :)
They have really solid mounting brackets, but the stainless bolts lock up after a while, so it pays to cover them with a protective silicone spray, or something similar :)
This is our experience, for what its worth :)
vacarosie200
Mon Jun 07, 2010 3:48 pm
using rb411+r52hn+rocket dish link = 11 km with obstacle in fresnel areea i get 62db on both sides and 125 mbps udp using rocketdish pigtails.
jspool
Mon Jun 07, 2010 9:38 pm
Awesome Thanks for the info!!! Wanted to make sure it would work before I pulled the trigger :)
ropebih
Sun Jun 13, 2010 12:45 pm
40 km link, rb433, r52Hn, 50 cm CDF200, 30 dBi rocket dish. TCP 90 Mbit (ping <10ms), UDP 110Mbit, signal -68.
Users browsing this forum: BT129863, MichalPospichal and 31 guests
