aaronw
Virtual AP not working
Sun Jul 04, 2010 1:32 am
Hi all,
I am running RouterOS 4.10 and attempted to set up a Virtual AP using the same settings as the default wlan interface but am having some problems.
I have an external DHCP server and have both the WLAN and VAP interface set up as DHCP relays. The WLAN interface is configured as 192.168.1.1/24 and the VAP as 192.168.2.1/24.
Whenever a wireless device attempts to connect to the VAP interface the DHCP server receives the requests and sends the response, but I see no indication that any packets have been transmitted out the VAP interface (tx counters remain zero).
I have no problems with the main wlan interface.
Both wireless interfaces are configured to use WPA2-PSK and the same security profile.
adrianatkins
Long time Member
Long time Member
Re: Virtual AP not working
Sun Jul 04, 2010 1:39 am
a wireless device
What equipment is the wireless device ?
Don't forget to give me at least a tenner a month, every month
SurferTim
Sun Jul 04, 2010 1:28 pm
Your dhcp server is sending an ip/subnet/gateway that matches each interface, correct? Just checking the simple stuff first.
adrianatkins
Long time Member
Long time Member
Fri Jul 09, 2010 12:59 am
Same SSID as well ?
SurferTim
Fri Jul 09, 2010 3:49 am
No. Different ssid. Different ip/subnet,
adrianatkins
Long time Member
Long time Member
Fri Jul 09, 2010 11:11 pm
Very odd. I use lots of VAPs with no problem at all.
Try deleting the VAP and re-creating it to see what happens.
What radio card is it ?
Does it make a difference which miniPCI slot it is in ?
pastranini
Sat Jul 31, 2010 2:16 am
I all.
Just A Comment
I had a lot of problems with Engenius Cards when i tried to setup 2 VAP in each interface i change the cards to r52h and inmmediatly worked.
Sometimes, we picked the wrong cards for different scenario.
pastranini
I all.
Just A Comment
aaronw
Sat Jul 31, 2010 11:42 am
a wireless device
I've tried several. An iPhone, a Windows 7 netbook and an Android Motorola Droid.
jorj
Tue Aug 03, 2010 9:50 am
Check if mac winbox sees your router from the wireless connected device, to check for connectivity.
If so, then you try setting up a dhcp server on the interface directly ( on the vap, meaning ), and see if you have connectivity.
Users browsing this forum: achiu and 29 guests
