psm
Wireless interface - Slave
Wed Jul 07, 2010 11:25 pm
Hello
Today evening i saw "S" flag on one of my wireless interfaces.
Can anyone tell me what it means ?
As you can see below, interface works in AP bridge mode and isn't ns2 or bonding slave.
Thanks for help :)
Regards,
adrianatkins
Long time Member
Long time Member
Re: Wireless interface - Slave
Thu Jul 08, 2010 1:20 am
A Bug maybe ?
Did it stop saying 'RS' when you quit Winbox and restarted ?
Did it stop saying 'RS' after you rebooted the mikrotik ?
Don't forget to give me at least a tenner a month, every month
maximan
Trainer
Trainer
Thu Jul 08, 2010 9:21 pm
I guess
R = running
S = Slave
On the screenshot appear "slave" on black letters
M.
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
psm
Thu Jul 08, 2010 9:34 pm
A Bug maybe ?
I quit Winbox and log in again - still slave.
After reboot .... still slave...
So... maybe it's a bug (v3.30)
I guess
R = running
S = Slave
M.
Yes. I know, it's (S)lave and (R)unning... but i don't know why it's (S)lave :)
Anyway... thanks for trying :)
Regards
adrianatkins
Long time Member
Long time Member
Fri Jul 09, 2010 12:10 am
Well, Up the Firmware revision and see what happens.
Actually, before doing that, just try these things (if you have time) :-
1. change the MAC of the second radio to 10 at the start instead of 00.
2. change the SSID of the second card to be X.... (i.e. start with an X)
reboot when you change something.
I'll be intrigued (and maybe a bit scared) to find that #1 stops it saying 'Slave'
maximan
Trainer
Trainer
Tue Jul 13, 2010 6:09 pm
export /interface wireless
Regards
M.
imaljko4
Fri Jan 17, 2014 2:26 am
Hello
Thanks for help :)
Regards,
I have the same question/problem.
My wireless card is set to ap-bridge mode ( no wds...etc.)
But when i check my interface it says "RS" (R-running, S-slave)
Dont understand why my Wireless is marked as slave.
RouterOS V6.7, RB751U-2HND
npero
Fri Jan 17, 2014 9:09 am
Because your interfaces is in bridge, that's makes S.
Check Bridge/Ports you interface is add there.
Lakis
Forum Veteran
Forum Veteran
Fri Jan 17, 2014 9:55 am
yes if the protocol mode is in rstp
npero
Fri Jan 17, 2014 10:33 am
Why need to to use rstp ? On all my devices protocol is none and also have S in bridge interface, of course we are talking about version 6.x ? In older version is different.
imaljko4
Fri Jan 17, 2014 12:19 pm
Yes, my wireless interface is added to the bridge.
But my Bridge protocol mode is set to "none" (No rstp).
(Ok. so probably as soon as it is in bridge mode, it ads S-slave to the interface)
npero
Fri Jan 17, 2014 1:44 pm
Yes because you are using v6.x.
Lakis
Forum Veteran
Forum Veteran
Fri Jan 17, 2014 9:13 pm
sorry I've made mistake in 6.x is different
I also don't use rstp I run in some problems with it, long story.
Users browsing this forum: No registered users and 39 guests
