el berto
Lost SSID on ap-bridge: how connect to station?
Mon Aug 16, 2010 10:53 pm
I had a routerbord in ap-bridge mode connected to a station wds.
I lost configurations on ap-bridge, so I don't know SSID on remote device.
How can I get it?
I know I can see SSID on station from ap-bridge through Snooper, but vice-versa?
thanks.
Ibersystems
Re: Lost SSID on ap-bridge: how connect to station?
Wed Aug 18, 2010 1:14 pm
1: You need to enter the WDS station router
or
2: You need to read your documentation about the installed AP-bridge
or
3: You can restore your backup file
or
4: You can use a linux distribution like backtrack with a wireless card with the Promiscuous mode enabled and see what is looking for this station router using aircrack-ng or something like that.
AFAIK is not possible to see the SSID of a station mode ap. Next time you should mark the "ignore SSID" on the WDS tab, to avoid this ; )
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
angboontiong
Wed Aug 25, 2010 2:46 am
If you are the owner, just login and check.
It's that simple, but i foresee you trying to access "somebody" network and plan to disturb it.
stop it.
Users browsing this forum: No registered users and 21 guests
