usmans
wireless beginner plz help me
Wed Sep 29, 2010 6:14 am
i want to configure mikrotik like this
Router <--> mikrotik <--> AP <-Wire less-> Clients
i have D-Link DWL-3200 AP .
plz someone explain in detail with picture.
thanks in advance....... :? :? :?
usmans
Re: wireless beginner plz help me
Wed Sep 29, 2010 9:42 pm
plzzzzzzzzzz help me...............
valypetre
Thu Sep 30, 2010 12:04 pm
You need to be more clear.
I understand you have a router connected to the internet, a Mikrotik routerboard and a D-link access point?
usmans
Thu Sep 30, 2010 5:06 pm
yes i have router connected to the internet and mikrotik router board and d-link access point
i want to configure like this
internet<------>dsl modem<------>mikrotik<---AP D-link--->clients
plz give me any tutorial i am beginner plzzzzz help
admin or any other member of this forum plzzzz help...
sorry for bad english
SEE THIS PICTURE
usmans
Sun Oct 24, 2010 12:03 am
plz help is this possible?
accessmd
Sun Oct 24, 2010 4:10 pm
Yes it is possible. Let me know if you have gotten a solution yet
usmans
Mon Oct 25, 2010 10:23 pm
plz post configuration image or video
thanks in advance
plzzzzzzzzzzzzz help
usmans
Tue Oct 26, 2010 5:09 pm
just tell me the wireless configuration in mikrotik
i run mirotik on pc x86 with two ethernet card and i have d-link 3200 ap
one ethernet card is connected to the dsl modem
and other is connected to the d-link 3200 ap
how to configure the 3200 ap in mikrotik
i want to run pppoe server in wireless network
i hope u understand (accessmd)
usmans
Wed Oct 27, 2010 10:01 pm
help help help :?
fewi
Wed Oct 27, 2010 10:14 pm
What have you configured so far? What step are you stuck on?
If you want someone to configure everything from scratch for you it's probably appropriate to pay a consultant.
usmans
Thu Oct 28, 2010 9:36 am
tell me how to configure d-link 3200 ap in mikrotik
just tell me assign the ip address to ethernet card which is connected to the d-link 3200 ap or configure someother settings in wireless interface?
see the above picture
i have already run wired network setup with pppoe server
i hope u understand what i am saying
sorry for bad bad english
thanks in advance
usmans
Thu Oct 28, 2010 10:30 pm
anyone help plzzz.........
fewi
Thu Oct 28, 2010 10:33 pm
Your diagram is unclear and I don't really know what you're asking. You have in no way indicated what you're trying to do. "I want to connect an AP" is not sufficient.
Are you trying to extend a network that already exists on the Mikrotik router? If yes, just plug a cable into a LAN port on the D-Link and the other side into a port on your router that is on that network, and set up the wireless parameters on the D-Link. Done.
If you don't know how to set up an IP address on an interface on a Mikrotik router, read the manual: http://wiki.mikrotik.com/wiki/Manual:IP/Address.
usmans
Thu Oct 28, 2010 11:43 pm
i have already wired network with pppoe server
you mean just plug one side of cable in D-link 3200 AP and the other side of cable into switch and setup parameters like Frequency ,Mode,and security etc,etc. on D-link 3200 AP thats it and then wireless clients can login with their user name and pass which are created in mikrotik.
Am i right?
fewi......
usmans
Fri Oct 29, 2010 1:47 pm
Am i right?
fewi......
accessmd
Wed Nov 10, 2010 4:43 am
I am trying to guess what your requirements are:
1. You will have to make your MT box to access internet. Connect one ethernet port to the DSL. If IP address is to be gotten authomatically, setup DHCP client on that interface.
2. Configure IP address on the other Interface
3. Setup a masqurade rule to allow clients connected through the LAN to access the internet.
4. Setup DHCP server on this interface
5. Connect the D-link AP to the LAN.
proggams2
Wed Nov 10, 2010 7:25 pm
You dont have any wireless configuration on mikrotik.
You need to configure your d-link using an ethernet cable and then plug the cable to the switch that is connected to the pppoe-server.
Muhammad
Sun Dec 12, 2010 3:19 pm
''usmans''
your problem solved or you need more help?
are you from Pakistan
any thoughts ???
think about Karma
usmans
Sun Dec 12, 2010 10:09 pm
''usmans''
i am from pakistan and my problem solved
Muhammad
Mon Dec 13, 2010 7:32 am
''usmans''
i am from Pakistan and my problem solved
Good
imran.khokhar@hotmail.com
00441785807099
any thoughts ???
think about Karma
Users browsing this forum: No registered users and 14 guests
