ekkas
Long time Member
Long time Member
WDS & WEP compatibility
Mon Sep 26, 2005 3:20 pm
Is Mikrotik WDS and/or WEP encryption compatible with other devices ?
I use mainly two units for client-side (or possible WDS hop)
1) Senao 3054 g units
2) D-Link DWL-2100AP
wildbill442
Mon Sep 26, 2005 4:17 pm
As long as your device supports WDS and WEP encyrption..... Then yes.
ekkas
Long time Member
Long time Member
Tue Sep 27, 2005 1:44 am
1) I had an MiniPCI card (AR5213) on router with 64bit WEP enabled but could not associate with a Senao CB3054 unit set as bridge. Disabled WEP and it worked immediately.
Any suggestions ?
2) I was adviced by my Mikrotik/Senao supplier not to use above config with 3054 set as AP, with WDS as it is apparently unstable :?
Any truth in that ?
rtr989
Re: WDS & WEP compatibility
Thu Feb 09, 2006 9:40 pm
can not make WDS connection with D-Link DWL-2100AP to the mikrotik 2.9.6 with Dlink-G520 on board, D-Link DWL-900ap+ and DWL-1000AP+ connects to the mikrotik using WDS perfectly, but 2100 not at all...
i try mikrotik 2.9.12 and another 2100, and 7100, same results...some times it connects for 1-2 minutes, then disconnect again, in registration list connection present Tx/Rx Rate 54Mbps/1Mbps, in statistic menu Tx/Rx Packets (some number)/0, all Tx-(some number)/Rx-0...
I try D-Link-G510 & AG530 in mikrotik, resulth the same...
rtr989
Fri Feb 10, 2006 8:59 pm
up!
ekkas
Long time Member
Long time Member
Fri Feb 10, 2006 11:37 pm
What did you do to make it happen ?
rtr989
Sat Feb 11, 2006 9:54 am
can you send me config file from Senao 3054, it`s use same atheros like in d-link 2100, i think what problem in d-link, i don`t use wep or wpa, just simple p2p bridge function...
my e-mail rtr989 @ list.ru
thanks at all!
rtr989
Mon Feb 13, 2006 4:43 pm
Alessio Garavano
Sat Apr 29, 2006 9:02 pm
Anyone try to do WDS between a MT and a Proxim AP4000?
Thanks!
Alessio
Alessio Garavano
http://www.isparg.com.ar
rtr989
Sat Apr 29, 2006 9:52 pm
Thanks!
Alessio
I try to do WDS between MT and a D-Link 2100AP, can not connect... :(
karyal
Sun Apr 30, 2006 12:15 am
I cannot tell for those equipment, but i have an MT box that is doing wep+wds (with CM9 at 2.4) for 10 Linksys wrt54g with Alchemy on them..
Bye,
Ricky
Alessio Garavano
Sun Apr 30, 2006 1:41 am
:) WDS between MT and AP4000 succesful...
Put the MT wlan pointing to the Proxim in ap-bridge, no encryptation and WDS mode dynamic ;)
Regards!
Alessio
Alessio Garavano
nowoxi
Wed May 31, 2006 5:46 pm
@karyal
pleasecould you help me out i am trying tomake thta same kind of connection but the linksys has ddwrt on it and there is a connection between the 2 but i cant ping form either sides of the network
luckystar
try
Fri Oct 20, 2006 3:48 am
Anyone try to do WDS between a MT and a Senao 3054CB3 Deluxe?
Thanks!
luckystar
Users browsing this forum: No registered users and 45 guests
