AK47
Upgrading Sierra MC8790 for RB411U
Sat Jan 08, 2011 3:07 pm
Hi there,
I am trying to get a MC8790 Mini-PCIe card working on a RB411U. The RB411U does detect the card, but the serial communications to the device don't seem to work.
I saw this topic about a firmware upgrade for the MC8790:
http://forum.mikrotik.com/viewtopic.php?f=7&t=35496
I have tried the upgrade on 2 Windows laptops with a Mini-PCIe slot but in both cases the upgrade software doesn't detect the card. For this I had removed the wireless card from the laptop and have put the MC8790 in that slot.
Does anyone have an idea how to upgrade this card?
AK47
Re: Upgrading Sierra MC8790 for RB411U
Sun Jan 09, 2011 5:40 pm
I managed to get things working without any upgrade of the MC8790. My RouterOS version is 5.0rc7.
This my config for connecting to the KPN 3G network:
[admin@MikroTik] > /interface ppp-client print
 0  R name="ppp-out1" max-mtu=1500 max-mru=1500 mrru=disabled port=usb2 data-channel=3
      info-channel=0 pin="" user="" password="" profile=default phone="*99***16#"
      dial-command="ATDT" modem-init="AT+CGDCONT=16,"IP","internet"" null-modem=no
      dial-on-demand=no add-default-route=yes use-peer-dns=no keepalive-timeout=30
Only problem I still have is the info-channel AND data-channel seem to be 3, so I cannot get any info when I'm connected.
Luissoares
Thu May 05, 2011 6:36 pm
Hi AK47,
I have similar problems.
Where do you find which is the DATA CHANNEL and INFO CHANNEL?
My present config is the following:
0 R name="tmn internet" max-mtu=1500 max-mru=1500 mrru=disabled port=usb2
data-channel=1 info-channel=0 apn="internet" pin="" user="tmn"
password="tmnnet" profile=default phone="*99#" dial-command="ATDT"
modem-init="" null-modem=no dial-on-demand=yes add-default-route=yes
use-peer-dns=yes allow=pap,chap,mschap1,mschap2
I Wasn´t able to find the KEEP ALIVE option to...
and
When i untick the DIAL ON DEMAND option i´am not able to put the interface on running mode
Can you help me with this 3 points (bold).
Cheers
Intrepid
Thu May 12, 2011 9:39 pm
@Ak47: thanks for sharing, i have the same problems with rb411u and a MC8781. Ill get autenticated, and after that, hungup...
The firmware upgrades didnt go well, since winxp didnt see the card, i tried 2 laptops.
Anyway, will test you're settings toworrow at work...
@luis: untik dial on demand and untik add default route, go to /ip firewall, make src-nat, action masqurade, then go to /ip route and add default route to ppp-out1.
It works like a dream for me on a rb433 with huawei e220 modem.
Intrepid
Wed May 18, 2011 3:50 pm
Problem solved.
I've used Windows 7, and did see AirCard 881U in the device list.
I downloaded firmware for Aircard 881U (MC8781) at the link below, ran the software and reset the mikrotik configuration, and everything works fine :)
Link to firmware:
http://www.sierrawireless.com/en/siteco ... _881U.aspx
Hope this helps someone :)
Users browsing this forum: No registered users and 51 guests
