xolture
7km wireless link @5.8ghz R52H+27dbi ant vs R52+30dbi ant
Mon Jan 17, 2011 8:21 am
Which will perform better for 7km Crowded 5.8ghz link?
I need about 20Mbps+ half duplex
RB411 + R52H + 27dbi Grid antenna
or
RB411 + R52 + 30dbi Grid antenna
Your advice appreciated.
thanks.
sonny
Re: 7km wireless link @5.8ghz R52H+27dbi ant vs R52+30dbi an
Mon Jan 17, 2011 11:57 am
take bigger antenna, is always better.
Because receive gain is better.
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
xolture
Tue Jan 18, 2011 3:01 pm
I choosed the Rb411 + R52 + 30dbi grid antenna combo
Today the link was up, and with hours of configuration I only can get max 5mbps throughput.
What card should I try next, r52h/r52hn/xr5 ?
any advices appreciated. thanks.
xolture
Tue Jan 18, 2011 8:19 pm
nvm, with nstreme, polling, and disable csma I could get 20Mbps half duplex.
n21roadie
Tue Jan 18, 2011 8:59 pm
I use XR5 cards and find them very good
If you have a crowded 5.8ghz then interference or co-channel could effect performance of any link using 5.8, I would consider using a different frequency?
N21roadie,
Network 100% MT for Now?
csallor
Tue Jan 18, 2011 10:39 pm
Try RB711 + 27dbi grid combo (or 44cm parabola). The best way..
mip
Wed Jan 19, 2011 9:30 am
I suggest UB5 cards, and 411aH.
Rb411 is for maximum of 30Mbps. So in the future you have no options.
Rb411ah is much better, and not so expensieve.
Try nstreme with exact isze (4000), turbo, special freq (5740,5760,5840).
At all grid is not a quite good option for long distance link.
But if you have no other choice, 30dbi grid should be good.
https://www.youtube.com/watch?v=j7q0Y_JZMrg - the country you must visit
mahnet
Long time Member
Long time Member
Wed Jan 19, 2011 7:29 pm
r52h/r52hn is always better than r52(has very little power for such long distance throw).
I would like to know why grid is not a good option for a 7km link.
n21roadie
Wed Jan 19, 2011 9:02 pm
Grids (or Dish) are the best choice for any link because of two advantages over panel antenna is their high gain and narrow acceptence angle, and this narrow acceptence angle can help with reduction in interference or co-channel pickup by stations off beam?
N21roadie,
mip
Wed Jan 19, 2011 9:16 pm
Because dish has less noise, bigger gain, and smaller angle.
Grid collects many noises from near location, and if its peer are far, its signal/noise rate falls.
mahnet
Long time Member
Long time Member
Thu Jan 20, 2011 8:48 am
So far I have never had problems with Grids. and dishes r heavy carrying to heights. Neways its just personal exp.
n21roadie
Thu Jan 20, 2011 11:23 am
?? Maybe someone has done side by side gain and signal to noise comparsion between grid and dish,
Another consideration is, if located on a high and exposed location is the wind loading factor by a dish,
Where you can mount a grid on any mast, a dish will require a more substancial and heavy duty mounting otherwise in stormy weather the dish will go off alignment.
N21roadie,
mip
Fri Jan 21, 2011 9:14 am
Yes, dish requires more money and more stable antenna holder.
Thats a fact. But it was about the link, not about the cost.
Higher quality most of cases means higher cost.
karlos
Sun Jan 23, 2011 11:39 am
You think BIGER is BETTER?
You cant solve your ignorance with bigger antenas or stronger cards.
Please start with looking on tha area:
do you have free sight ?
free fressnell area ?
do you have some reflection materials nearly or in the link direction?
etc.................
Than discover for another wirelles:
how noisy is your area?
did you find some "clear" channel?
Configuring link
did you some indoor performance tests of your configuration?
is there some another limitation, like cpu speed, forgoten que
....... try to think about
Finding solution / find what is wrong
CPU load too high
Low signal compared to calculated "should" values
Wrong CCQ
Good signal but low modulation
So what is wrong on your link ?
R52 + 27dBi antenas
hmmm ... do you have -56/-56dB signal ? if not, try to start with finding wire, aligment or another problem.
for 7km link you dont need this "extra" power, and "TOO BIG" antenas makes just too strong input sensitivity, and the cards must just listen to too strong signal form another sources (too much noise)
R52 + 24dB antenas is enough avaiting -62/-62dB anough for good link
try antenas like that Image for better noise imunity from nearby sources.
Tell us more about you r configuration and actual values from your link
Users browsing this forum: No registered users and 10 guests
