MUM Europe 2020
mughal125
R52hn with airmax sector antenna
Wed Feb 09, 2011 11:07 pm
Hi everybody .
I want to use R52hn with airmax sector antenna .
the model number of antenna is airmax 2g-15-120 .
you can find specification from this link .
http://ubnt.com/downloads/AirMax2GSectors.pdf
please confirm me that is this antenna work fine with R52hn ?
WirelessRudy
Re: R52hn with airmax sector antenna
Thu Feb 10, 2011 3:40 am
Why not?
I´m planning to do the same. The Airmax antenna is need, compact design but I don't like the ubnt OS. I prefer MT. You only have to find the right cables to attache a rb radio to these connections of UBNT.
As far as the antenna is concerned it is presented a radiowave by the radio. The radio wave has no tag on it saying it was produced by "x" manufacturer. So the radio can be any make, the wave it produce will have to be of the same nature. Differences in protocols, modulation, TDMA or whatever is digital info the radio's on both ends have to work with. But the electromagnetic radio wave is the only aspect the antenna is made for.
So imho if the Airmax antenna is as good as they say combined with the design I think it is a very good combination with rb.
blake
Thu Feb 10, 2011 7:28 am
They work great. I have several 2G-16-90's on R52HN's and R52N's. No issues.
IT consultant. Network manager. Packet junkie.
1-928-328-1509
mughal125
Thu Feb 10, 2011 12:56 pm
thanks for replay .
can anyone suggest which pigtail is best for connect R52Hn to AIRMAX SECTOR 2G-15-120 .
mgutz2
Tue Feb 15, 2011 7:52 pm
I recommend you use one as short as possible
ericsooter
Wed Feb 16, 2011 5:01 pm
Same here, worked great. Mine is on a 220 ft cell tower. I did run into surge problems because I was using a short sma to N pigtail. I had to use a slightly longer jumper and ground it; also added a couple 5ghz lightning arrestor and all has been good for about 15 months. (in a very heavy lightning area). Before the grounding I was losing the Mikrotik boards on almost every other storm.
popcorrin
Thu Feb 17, 2011 7:05 pm
Were you losing the boards or just the radio cards? What card and boards are you using?
Users browsing this forum: Binser, Zacharias and 24 guests
