tnakir
Our SXT testing
Thu Mar 10, 2011 12:52 pm
We managed to achieve stable 150Mbit TCP throughput with 2 SXT connected to 2 computers. We used IPerf with 4 threads. Some of our friends established 200Mbit TCP link on 3 km distance. So far, we're happy with the device. Nice job MT!
arroyo
Re: Our SXT testing
Thu Mar 10, 2011 4:07 pm
I spent a lot of time with testing of SXT but I still did not find the right setting.
I try to do PtP with two SXTs, but in bandwidth test I achieved only about 35 Mbps.
I am really desparate.
Would you by so kind and want to share your setting?
Thank you.
uldis
Re: Our SXT testing
Thu Mar 10, 2011 4:51 pm
Is it UDP or TCP bandwidth test?
Many laptops with 100Mb/s ports can only do ~30Mb/s, especially the older ones.
Make sure that you use latest version or v4 or v5.
I suggest to reset the wireless configuration and configure to use both HT chains and enable the Nv2 protocol to get max speed.
rodneal
Re: Our SXT testing
Fri Mar 11, 2011 4:20 am
How do you make a P-to-P connection between two lvl3 SXT units? Doesn't one of them need to be lvl4? Otherwise these units are a waste of time!
uldis
Re: Our SXT testing
Fri Mar 11, 2011 8:16 am
Use mode=bridge on one side and mode=station on the other side - that is all the magic you need to make point-to-point connection with Level3 ;)
ste
Re: Our SXT testing
Fri Mar 11, 2011 8:31 am
@uldis
Tested Sxt found it a very good device. One thing is
annoying. There is not enough space to plug in our
standard Ethernet cables with kink protection.
Please talk to your board designer to move the
Ethernetport to the middle of the board by 2cm.
normis
Re: Our SXT testing
Fri Mar 11, 2011 9:14 am
@uldis
for indoor tests you might find this, but normally you don't use patch cables on the roof. if you use regular ethernet cable, there is no problem like this. cables longer than 1m don't have those kinds of connector
rodneal
Re: Our SXT testing
Fri Mar 11, 2011 8:34 pm
Thank you!
Rod
t3rm
Re: Our SXT testing
Wed Mar 16, 2011 4:09 pm
150Mbit you mentioned here must be 75Mbit TX and 75Mbit RX right ?
or 150Mbit TX and 150Mbit RX ?
I am using old Realtek PCI and managed to get only 70Mbit Full Duplex.
Perhaps the new Gigabit Ethernet will help to get 97Mbit Full duplex ? he he he he :p
chemcat9
Re: Our SXT testing
Mon Mar 21, 2011 8:35 pm
Can you provide how you would do this via Webfig?
Thanks in advance!
meno
Re: Our SXT testing
Wed Mar 23, 2011 7:56 pm
Try to update your NIC driver, windows driver wont work propely
tnakir
Re: Our SXT testing
Wed Mar 30, 2011 9:24 am
@t3rm... yes 75 + 75Mbps. And a little update, our friends managed to achieve ~98 + ~98Mbps link on 500m distance.
@MT Staff: When will SXT get CE?
t3rm
Re: Our SXT testing
Wed Mar 30, 2011 7:12 pm
Yes, this afternoon, local Mikrotik Forum posted that SXT able to punch 90Mbps full duplex packets,
My mistake is testing this on old laptop.
Will test with the newest notebook and PC, or RB750G :)
wkstill
Re: Our SXT testing
Sun Apr 03, 2011 6:29 am
can someone post their config?
I am trying two SXT lvl3 PtP , got the connection up, but can't get more then 30Mbps Either Direction.
Distance is 500 Feet.
tgrand
Long time Member
Long time Member
Re: Our SXT testing
Thu Apr 07, 2011 10:48 pm
Every situation requires different settings.
It is not just something that can be exchanged.
I would venture to guess that the rx signal on either end of that 500m connection is stronger than -50.
First thing I would recommend is to lower your tx-power in increments and check your speeds.
Work to try to find the optimal settings for your particular link.
uldis
Re: Our SXT testing
Fri Apr 08, 2011 10:09 am
By default the SXT board has only one chain enabled. You need to enable the second chain to use both polarizations.
Another suggestion is to enable the ht-extension-channel in order to get 2x20mhz channel option. Both options are located in the HT wireless tab.
We will improve the default configuration on the SXT board so it by default would use both chains.
Users browsing this forum: davidreaton and 39 guests
