Ngs
Only from 10 to 25Mbit/s per one connetcion in NV2
Mon Mar 14, 2011 11:04 am
I think it's a bug. In WDS mode p2p if user download in once connection he has from 10 to 30 Mbit. If i change mode to nstream he has 62Mbit/s per 1 connection.
Can it be fixed?
Version 5.10 Ptp with wds mode. Only g 2,4 Ghz 40 Mhz
Per 10 connection in tcp we reached 85Mbit/s.
Thx for help
uldis
Re: Only from 10 to 25Mbit/s per one connetcion in NV2
Mon Mar 14, 2011 12:27 pm
please provide more info on your setup. What hardware are you using for this setup? what utility you use for testing the speed?
Ngs
Mon Mar 14, 2011 1:01 pm
I use routerboard 433AH + Chipset 5213. Link p2p with WDS.
Testing with downbload from ftp or from bandwith test
uldis
Mon Mar 14, 2011 1:36 pm
make multiple support output files when you do those test:
1. when you use Nv2 and send one connection
2. when you use Nv2 and send 10 connection
3. when you use Nstreme and send one connection
Send those files to support@mikrotik.com
The test is done from the windows PC that is connected to your RB433AH board? and the bandwidth test is also made from the windows?
Lakis
Forum Veteran
Forum Veteran
Mon Mar 14, 2011 6:58 pm
//I think it's a bug. In WDS mode p2p if user download in once connection he has from 10 to 30 Mbit. If i change mode to nstream he has 62Mbit/s per 1 connection.//
it's not a bug its normal for nv2
for p2p just use nstream
nv2 is for p2mp test it with 5 or 10 clients than u will see the benefit of nv2
Ngs
Mon Mar 14, 2011 7:44 pm
I'll send to support in few day, i can't experement with working link.
I also have benedit in p2p link. I have 85 mbit but in nstream 70. Realy 15Mbit/s and it's better work's with noise.
If in nstream in some frequency i had 50Mb-60Mbit/s in Nv2 i always had 80-85.
uldis
Tue Mar 15, 2011 10:11 am
Nv2 is also good for point-to-point installations. Will wait for the support output files.
Polky
Sun Nov 13, 2011 9:39 pm
Hi, I know the answer from support? Basically, all connections with NV2 behave worse than the Nstreme, if used only a single connection. It's bad, because all clients use the speed tests that use a 1 connection.
THX
uldis
Mon Nov 14, 2011 12:19 pm
THX
Please write to support@mikrotik.com we will provide you with a test release of v5.9 which has lot of improvements using Nv2.
Fumi
Thu May 10, 2012 1:04 pm
There are news about this topic? I have the same problem with nv2 connections.
Users browsing this forum: Baidu [Spider] and 58 guests
