surfnet
Hotpsot M/k to another Hotspot M/k.. problem with proxy
Sat Oct 22, 2005 2:44 am
I currently have a Mikrotik setup with Hotspot.. and all it well. I then used another mikrotik to connect to the first on its hotspot interface. on the second Mikrotik there are 2 radios. one that backhaul to the first mikrotik through the hotspot and the second radio is for local clients. All this works great until...
I add a hotspot to the 2nd mikrotik.. When I do this everything works except port 80. I get a 401 Proxydenied error message. I feel like the problem is that I am doing a 'double proxy' I noticed that in the Hotspot server profile there are boxes for Proxy server and Proxy Server Port. I think these should be set to the 1st mikrotik.. but I was hoping someone could tell me that I am correct before I f*ck the cleints connections once again..
Also I need to know if I need to add a port as well as the IP address of the upstream Mikrotik
thanks!
Ken
surfnet
Tue Oct 25, 2005 8:35 pm
bump
anyone even tried this senario ?
Ken
sandov63
Re: Hotpsot M/k to another Hotspot M/k.. problem with proxy
Tue Jun 24, 2008 1:14 am
yes i have same configuration and just this time im configuring ip and por to be the other mt, thats the problem and , altouhg im passing trough the first mt witout pasing trough the hotspot i ihave same problem,, excuseme for my poor english
Cuando la ignorancia se impone, la razon cordialmente cede el paso.
Users browsing this forum: Agraham01, Bing [Bot], Paranlo and 70 guests
