MUM Europe 2020
server8
SXT 5HnD + USB 802 b/g/n AR9271
Fri Apr 22, 2011 1:53 pm
Hi guys, I am planning to setup a network of several 2.4 Ghz access points, I am testing SXT L4 license (backbone) + USB 802 b/g/n AR9271 wireless stick (access point) like tp-link TL-WN422G http://www.tp-link.com/en/products/prod ... 03&id=2615
The system recognize the usb stick and it seems to work (a little bit instable :D ) but the main problem is that I have a very small coverage area, I tried to change the antenna with big one but the problem persist, my idea is the driver is not perfect and it don't manage well the output power or something similar.
Any ideas to solve this issue? SXT + usb stick is a cheap all in one solutions.
Thank you Giuseppe
server8
Re: SXT 5HnD + USB 802 b/g/n AR9271
Sat Apr 23, 2011 1:22 pm
any ideas?
thanks
lazerusrm
Mon Apr 25, 2011 10:07 am
i think it might help your case to post some winbox shots with a client or two connected to the AP to determine if it may be a hardware, software, or configuration issue.
talo1019
Mon Apr 25, 2011 11:33 am
Isn't SXT a 5GHz a/n device while your tp-link TL-WN422G is a 2.4GHz b/g/n?
I don't think it has to do w/ the driver. You're AP should be a/b/g/n, that might help solve part of your problems.
InoX
Mon Apr 25, 2011 11:46 am
:lol: :lol: :lol:
server8
Mon Apr 25, 2011 7:32 pm
Sorry I explained in bad way and I apologise for my bad english.
I connect the TL-WN422G (or TL-WN722N) to the usb port of the SXT to use it like as a 802.11 b/g (or N) card in AP mode. The system works but it is very unstable:
- poor signal just after few meters (I tried several 2.4 antenna via external connector)
- clients are not cancelled by registration list after disconnection
- in registration page last activity change but client is disconneted
- during bandwith test from PC to SXT system sometime crashes or disconnect (I need to reboot SXT to connect again)
- in 802.11 B/G mode no signifcative signal difference changing the antenna from A to B (I tried several 2.4 antenna via external connector)
maybe AR9271 driver is not good. But I like the idea to use SXT + USB like a small all in one PtP + AP solution.
Giuseppe
InoX
Tue Apr 26, 2011 12:52 am
popcorrin
Thu Apr 28, 2011 6:50 am
how can you find what chipset the usb adapters are using?
normis
Thu Apr 28, 2011 7:45 am
you need to make a supout.rif file and send to support, it seems that there is a problem with supporting certain USB wireless cards
server8
Mon May 09, 2011 3:24 pm
I did it last week I am waiting for an answer
Thank you
altnet.md
Sat Jul 16, 2011 1:14 pm
if usb wifi on AR9271 did not work then tell us what devices we can use ?
normis
Mon Jul 18, 2011 9:57 am
which USB wifi did you use? which RouterOS version? on SXT?
altnet.md
Mon Jul 18, 2011 4:28 pm
TL-WN422G , ros v5.5 on SXT
tahnan
Fri Jun 15, 2012 8:00 pm
Hi guyes, I've installed mikrotik os 3.20 to one of my pc. I would like to make a hotspot using tp link TL-WN422G. Can anyone help me how to do it? my mikrotik is not getting this device when i'm plugin it to usb port of that mikrotik. any help?
altnet.md
Mon Jun 18, 2012 9:17 am
this device is not supported by ROS v3 ... try v5 and v6
Users browsing this forum: No registered users and 29 guests
