MUM Europe 2020
technalogic
control frame timeout
Tue May 03, 2011 11:49 pm
i got this error control frame timeout in my sxt client what is this ?
WirelessRudy
Re: control frame timeout
Wed May 04, 2011 2:52 am
Weak radio link or/and interference from other networks.
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
kkolev
Wed May 04, 2011 10:52 am
I've seen frequent (2-3 times per hour) "lost connection, control frame timeout" or "lost connection, medium-access timeout" on a almost perfect link with -60 signal when it was idle. If only 1Mbit bothway traffic pass through it and no more "lost connection..." . But your link might have some issues.
technalogic
Wed May 04, 2011 10:54 am
i have -79 signal with 60% ccq
lazerusrm
Wed May 04, 2011 11:54 am
How far are your links, have you measured them? what do you have set in the "Distance" setting on both radios under the advanced wireless tab? what about your NV2 cell radius?
maybe post your configuration too. :)
WirelessRudy
Thu May 05, 2011 1:44 am
For normal 802.11 this is marginal signal, for nv2 I would say it is poor and insufficient.
Rudy R. Puister
jimmyxing001
Fri May 06, 2011 10:45 am
i think should your channel is using by other wireless or your signal is not good
lazerusrm
Sat May 07, 2011 5:14 am
Yes this is true, but i have a very stable link with NV2 at -83/-80 dB. & 68/45 CCQ I get about 15 megabits each direction, and i dont have connection drop problems. Although i use NV2 A Mode. Its faster than N at those signal levels, i do only have single chain on the AP side. (Client is an SXT Single chain mode)
perhaps there is more to the story.
-Brad
WirelessRudy
Sat May 07, 2011 6:29 pm
-Brad
15Mb in each direction? Not at the same time I presume (that's impossible) and at what cost? Your latency will be very high and voip on such a link will be very poor at best. (too many packages get lost and too many delays for the ones that make it...)
I don't know if N would perform worse under such signal levels. The whole design is that with same distance/signals levels N protocol should almost be able to quadruple the throughput. Or, with the same throughput as goal the reachable distance can be much further to still have a communication going on.
But each technology used needs its fine tuning to get the best out of the available parameter settings.
It is not that one protocol can be exchanged for another to see the difference in capacity between the two.
Like a F1 car won't bring you faster from one city to another than the average car. [One of the changes you probably would have to make to the F1 is put it on higher suspension to at least make it able to run faster on the average road!]
In other words, each protocol has its own adjustments to the environment it is set to work in to get the best out of it.....
Rudy R. Puister
Users browsing this forum: No registered users and 23 guests
