vahid023
how to Bridge 2 mikrotik device (sxt , 433ah )
Mon May 09, 2011 12:36 pm
hi
in sxt, ether1 and wlan1 is bridged. and bridge has 192.168.1.53/24 ip.
in rb433 ether 3 has 192.168.1.52/24
my rb433 connected to sxt with ether 3
now the problem is that i can ping sxt from rb433 but cant ping other 192.168.1.x device that connected to wlan1(sxt)
note that sxt can ping them!
MICPROF
Re: how to Bridge 2 mikrotik device (sxt , 433ah )
Fri May 13, 2011 8:04 pm
Dear ,
You can use bridge in two side from SXT and RB433 , or use EOIP link between us , this good idea for use EOIP for link ...
Thanks!
Best Regards.
If my answer helped you and my question good too, please give me karma
krakenant
Tue May 17, 2011 6:58 pm
sdischer
Trainer
Trainer
Sat Jun 04, 2011 11:28 pm
You can bridge the ap in ap bridge mode or bridge mode. You can not bridge the station without using station wds mode. Search the wiki fir transparent bridge. Mpls and EOIP tunnels are also options but a bit harder to set up.
Steve Discher
LearnMikroTik.com, USA
RouterOS Training and Consulting
Get Certified!
http://www.LearnMikroTik.com
yogii
Thu Jul 14, 2011 8:14 pm
hi.. i have same problem and i'm newbie total in wireless.
could i make bridge interface for wlan interface and ehternet interface in RB433 and SXT too? after that could i ping from network under ehter SXT interface to network under ehter RB433 interface?
please need your help.
kirshteins
Fri Jul 15, 2011 9:53 am
vahid023, are there any IP or bridge firewall rules on SXT that could block this ping?
Naderpour
Trainer
Trainer
Fri Jul 15, 2011 10:17 pm
in sxt, check the wireless mode you are using, some of them can not be used when you add wlan as a port in bridge. your bridge seems not working correctly now.
Users browsing this forum: No registered users and 26 guests
