Hi All
Im about to install my first MT based bigger install which will consist of :
RB1100 gateway controller running hotspot server
RB433Ah , 1 card , 90 deg sector
The Hotspot units will run an SXT connecting back to the RB1200 , plus 2xMT Radio cards to be decided in an RB433Ah
The 2x MT radio cards will need to handle a high concurrent user count (approx 100)- how do you tie the 2 cards together to spread users over the 2cards?
I am going to run the card APs on channels 1,6,11 over the site - will this support client roaming?
How do I bridge the AP Radios direct to the gateway controller, whilst allowing the the main infrastructure to be managed? Im assuming I use VLAN?
Bandwidth is very small, no more than 8mb outbound ADSL, although extra ADSL will be added over time. Not all users will be having internet access , most will be using local network. Client speeds are going to be 25k/12k
I am happy to pay someone for a couple of hours of their time for advice on this, but am unable to make use of the PM function.
email at richedav@gmail.com if you wish
