MUM Europe 2020
conchalnet
Maximum users on the AP
Wed Nov 09, 2005 2:43 pm
Hi all,
What's the maximum users that can I have in my AP???
PS: My clients can have access with 200Kbps and 400Kbps.
normis
Wed Nov 09, 2005 2:53 pm
well 50-100 maybe?
scurtis@acrsokc.com
Sat Dec 03, 2005 8:31 pm
What if I have three sectors fed by three PRISM 802.11b radios? All PPPoE? I give lots of BW (3meg).
Jrslick22
good question
Tue Jan 31, 2006 12:11 am
1 run 50 512 users of a single b sector fine
djape
Tue Jan 31, 2006 2:06 pm
I can say for associated clients there's no limit, but over 50 performance becomes very bad...
I drink like a pirate and smoke like a hippie...
acim
Sun Feb 05, 2006 11:57 am
@djape
Does it really depend on number of clients or their total bandwidth? I mean, if performances drop by number of clients, then probably faster CPU's can help and it is probably not the same if you have 50 clients using 64K speed or 50 clients using 256K speed. What are your experiences?
And BTW, are you member of http://www.linuxserbia.com/forum? If not, I would like you to become a member and hopefully a moderator also :)
Pozdrav!
cibernet
Long time Member
Long time Member
Sun Feb 05, 2006 1:06 pm
@djape
Pozdrav!
It depends of the speed of the client, distance of the client, if its downloading or just browsing, etc...
Regards
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
djape
Mon Feb 06, 2006 1:06 pm
Hi acim, thx for invitation ;) I am not a member but I'll do it right away.
I am talking about 802.11b.
CPU can't help here, it's a card actually the one that can't process a lot of connections, packets/second.
As cibernet wrote it depends what kind of traffic you have.
So basically number of associated clients is not a problem as far as amount of traffic is not killin' performance.
I have APs with 40 clients connected at the same time, they use regular http, icq, mirc etc. and APs are working great (2mbit/s average comsumption).
On other hand, I have APs with 20 clients, but these guys are Internet killers (p2p, all sorts of junk traffic) and AP consumption is ~0.5mbit/s.
Remember, just one client with junk traffic can kill your AP.
So, filter viruses, use mangle, queue tree, limit concurrent connections per IP, turn off default forwarding, fight for your AP :D
There are people here sayin' I don't want to limit my costumers!!!
Well, I'm doing this for their own good! They can't get wild on AP!
They can use internet as God said! There most be some quality of service and priorities. It could be called Order of da House :D
Cheers folks....
acim
Mon Feb 06, 2006 2:45 pm
I thought so, but anyhow thanks for the confirmation.
Alessio Garavano
Mon Feb 06, 2006 11:21 pm
i have a RB532 w/R52 wlan doing hotspot, firewall rules, p2p limit, etc etc and when connect about 80 clients all work fine, but at 2hrs the router lose effectivity and the clients are disconnected, but nothing debug rare in the MT Syslog and the CPU Load is very light...
what can be? what`s happen when the RB is overloaded by clients? this crash or is my situation?
Thanks!
Alessio Garavano
http://www.isparg.com.ar
Catsix
Re: Maximum users on the AP
Mon May 06, 2013 11:28 am
This comes from the wiki, I guess this is the soft/hardware limit:
max-station-count (integer [1..2007]; Default: 2007) Maximum number of associated clients. WDS links also count toward this limit.
From experience I set BW limit to 4Mbps/client and can have 600 clients connected on a 50Mbps internet connection with no complaints.
But this is in a distributed environment. Never had more then 20 clients connected to one AP.
Users browsing this forum: No registered users and 31 guests
