MUM Europe 2020
dallas
Long time Member
Long time Member
Groove 2.4ghz
Fri Aug 05, 2011 6:37 pm
I will buy hundreds if you can make this product in 2.4ghz frequency. Please make this Mikrotik. Whats your thoughts?
Cell# 507-383-8012
dallasweitzel @ gmail.com
Network and RF engineer
Traffic Engineer
Dallas Weitzel
richedav
Re: Groove 2.4ghz
Fri Aug 05, 2011 7:13 pm
I'll second that - just installed 90 Engenius3500 when 2.4 groove would of been much better.
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Fri Aug 05, 2011 7:45 pm
Would be nice if it was 24dbm not 20dbm. That way there is a lot of nice priced antennas to go with the groove. If you can go higher that. That still would be nice.
The groove has 15dbm at 54mbps which is almost nothing. I would need a very high dbi antenna. Which price goes up. If we had little higher dbi the overall price would be good. Thanks in advance.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Fri Aug 05, 2011 9:46 pm
I see the omnitik is 400mw. Why not the groove? 400mw will work for 5ghz and 2.4ghz.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
angboontiong
Re: Groove 2.4ghz
Sat Aug 06, 2011 6:18 am
if you can make it like the Altai C1 spec, we will more than happy buy few hundred unit.
0ldman
Re: Groove 2.4ghz
Sat Aug 13, 2011 12:12 am
another vote.
The 2.4GHz Mikrotik equipment has seemed a little left out of late.
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Sat Aug 13, 2011 12:27 am
Mikrotik are you trying to not use amplifers in your equipment?
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
0ldman
Re: Groove 2.4ghz
Sat Aug 13, 2011 6:45 pm
While I like and sometimes need the higher power units, I see why they don't have amps on every device.
The Crossroads I have sometimes do not like the lower power settings. I have a few that I could swap out for lower power units, however they are not easy to get to. If set below 10dBm then we have some issues.
The RB711h2n has 27dB tx, sounds like it has an amp to me. I am looking forward to trying it, as well as a 2GHz Groove and Omnitik. I'm feeling a little left out by all the 5GHz focus.
I would like it if MT would bring a 900MHz 802.11n option to the table. Ubiquiti's M9 products are great and all, but you cannot disable TDMA and it will cause self interference.
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Mon Aug 15, 2011 5:33 pm
anything over 200mw is amped.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Mon Aug 15, 2011 5:34 pm
A minipci 802.11n 30db card is coming out soon. We can use that card with mikrotik.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Mon Aug 15, 2011 5:35 pm
It might be 28db. I am talking with the manufacturer.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Fri Sep 16, 2011 11:50 pm
Actually I dont care if the power is more than 200mw. I want the groove 2.4ghz.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Fri Sep 16, 2011 11:51 pm
I want to use this for my 2.4ghz clients.
1. Less electronics, less chance esd will aim at it.
2. Very easy installation
3. Light wait
4. Very flexible for antenna sizes
5. Very cheap replacement costs.
6. Its Mikrotik!!!
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
InoX
Re: Groove 2.4ghz
Sat Sep 17, 2011 1:38 pm
who are you talking to?
ditonet
Forum Veteran
Forum Veteran
Re: Groove 2.4ghz
Sat Sep 17, 2011 10:39 pm
"I like to do all the talking myself. It saves time, and prevents arguments." - Oscar Wilde
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Sat Sep 17, 2011 11:03 pm
haha that is awesome. Thanks for the humor. I guess your right. ;)
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
rodolfo
Long time Member
Long time Member
Re: Groove 2.4ghz
Sun Sep 18, 2011 9:19 am
a groove in 2.4GHz kills all picostations M2 I use as street access point
rodolfo
IZ0UQV
normis
Re: Groove 2.4ghz
Mon Sep 19, 2011 9:05 am
I would look at this the other way. If something dies because of simple interference, it's not a good sign.
rodolfo
Long time Member
Long time Member
Re: Groove 2.4ghz
Mon Sep 19, 2011 7:50 pm
:D :D :D
sorry!!
I mean: "a 2.4GHz Groove "commercially" kills picostations"
rodolfo
IZ0UQV
normis
Re: Groove 2.4ghz
Tue Sep 20, 2011 7:55 am
:D :D :D
sorry!!
Sorry, I misunderstood that statement :)
Lakis
Forum Veteran
Forum Veteran
Re: Groove 2.4ghz
Wed Sep 28, 2011 10:40 pm
1.400mw 2.4 is no legal in EU max 100mw /Any way Groove or SXT 2.4Ghz ver. will be good
2.400mw 5150-5350Ghz is also no legal in EU max is 200mw from 5490-5725 u can use up to 1W
3.Always try to use less mw (less noise) - instead use bigger antennas
so MT dudes pls dont make 2.4ghz 400mw Sxt or Groove it will kill the spectrum :)
What batter me a lot is why groove sxt or any MT N-standart wireless cart are not supporting 5ghz-A (only A) 40Mhz channel with?
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Wed Sep 28, 2011 10:52 pm
Thanks for the informations. 2.4ghz 400mw is legal right. That is 26dbm? Put a 10dbi antenna and you got 36dbm which is 4 watts of power. Let me know what you find. thanks again.
Overall I do agree that 200mw is a great groove 2.4ghz. So I am waiting for mikrotik to build it.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
chadd
Re: Groove 2.4ghz
Thu Sep 29, 2011 7:19 am
The only problem with a 200mW/23dBm single chain N Groove is that at higher modulations MSC7 the output power is only going to be ~16dBm. I think you would be better off starting at 400mW/26dBm and ending up with ~19dBm @ MSC7. This is going to give you a better chance of maintaining higher data rates and would allow you to lock your data rates to higher rates if you wanted.
normis
Re: Groove 2.4ghz
Thu Sep 29, 2011 7:33 am
we will have 2GHz Grooves, don't worry :)
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Fri Sep 30, 2011 5:06 pm
awesome.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
Lakis
Forum Veteran
Forum Veteran
Re: Groove 2.4ghz
Fri Sep 30, 2011 9:13 pm
One I cant understand why groove is not made to support on both freq. 2.4 and 5ghz
I understand sxt have 5Ghz integrate antenna and there is no point to support 2.4ghz
but groove dont have integrate antenna just u can put radio chip like on R52Hn witch support 2.4 and 5Ghz
dallas
Long time Member
Long time Member
Re: Groove 2.4ghz
Fri Sep 30, 2011 9:22 pm
Yeah I agree, they probably wanted to use a cheaper chip set to make the product cheaper for us. Thats good with me.
Cell# 507-383-8012
Traffic Engineer
Dallas Weitzel
nawas
Re: Groove 2.4ghz
Sat Oct 08, 2011 5:39 pm
---waiting the groove 2.4
We are still waiting eagerly for the new product.
..any news? :(
RAHQGideon
Re: Groove 2.4ghz
Thu Dec 29, 2011 4:56 pm
Any idea when the 2.4 will be launched? We have a rolout to replace 30 UBNT bullet2 radios and these will be perfect. :D
I wouldn’t’ be asking if I knew how it works !!!
ilius168
Re: Groove 2.4ghz
Mon Jan 02, 2012 5:51 pm
patiently waiting....
kembiet
Re: Groove 2.4ghz
Mon Feb 27, 2012 12:45 am
how long still to wait?
Users browsing this forum: arkadiuszlobodziec, frankko, s17 and 24 guests
