MUM Europe 2020
angboontiong
script to check the ethernet status....
Tue Sep 06, 2011 4:19 pm
Hi buddy...
is there anywhere we can have a script that, when it detect the ethernet under 10Mpbs mode, it can send the email.
appreciated it.
WirelessRudy
Re: script to check the ethernet status....
Wed Sep 07, 2011 3:18 am
Hi buddy...
appreciated it.
Enable interface logging in 5.6 and you get the status of the Ethernet link in your log. Set the log output for this topic to ´remote´ and use the mail option. Configure your mail settings.
Now you get an e-mail every time the Ethernet status changes. But "under 10Mbps"? Meaning it is disconnected?
Ethernet interface in MT can only do 10/100 and some rb's 1Gbps.
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
angboontiong
Wed Sep 07, 2011 6:56 am
Hi buddy...
appreciated it.
Hi bro..
we notice some of the board will degrade to the 10BaseT mode, and when this thing happened, we only know when customer is complaining (10Mbps subscriber).
Would you mind to tell me more about this?
btw, usually, some time it can fix by upgrade the firmware, some time we need to replace the board.
appreciated it.
Ivoshiee
Wed Sep 07, 2011 8:29 am
It is quite similar to symptoms of the port flapping issue:
http://forum.mikrotik.com/viewtopic.php?f=2&t=54038
Does these 10Mbps interfaces bring itself back up to full speed 100/1000 by itself as well?
angboontiong
Wed Sep 07, 2011 8:54 am
it may... some time.
Ivoshiee
Wed Sep 07, 2011 9:26 am
I think you have the same port flipping issue, just your port flipping duration is (much?!) longer.
I am not detecting port speed changes, but I am fighting the issue with Netwatch tool and scripts detecting if the interface is actually down or not.
WirelessRudy
Wed Sep 07, 2011 12:02 pm
Yes, with me they do. Some several times a day....
Rudy R. Puister
angboontiong
Wed Sep 07, 2011 12:39 pm
Hi bro..
then how you go and fix it?
this is something... really an issue.
WirelessRudy
Wed Sep 07, 2011 12:48 pm
Hi bro..
Distilling what could be the issue by what users on the forum report. And hope MT will do the same until they find a solution....
Rudy R. Puister
Ivoshiee
Wed Sep 07, 2011 2:05 pm
Hi bro..
On my RB750G I just rearranged the port use away from affected ports (port1 and port2) and implemented some scripts to kick in to switch over to an alternative ISP connection in case of link down or more generally the primary ISP being unavailable.
I haven't tested it, but maybe invoking interface down and up again will bring it into life again. You can use Netwatch tool for that purpose.
Users browsing this forum: No registered users and 14 guests
