MUM Europe 2020
dunga
best advice for this wireless link (point to point link)
Mon Oct 03, 2011 5:15 pm
hello all,
I just established a point to point link with 2 mikrotik radio (rb411) both, one as bridge and the other one as wds.
What i get as my signal strenght is -76/78, in 5ghz. When i ping, i get response of 1ms. Is there a way i can do any thing to improve the speed? What benefit do i have if i configure it as nstreme dual.
In the two radio is i run bandwidth test the response time increased to 563ms while with d test it replies 1ms.
Please your advice and suggestions are needed urgently here as i need this link to support over 8mbs of bandwdith in full duplex.
see the pictures below
Please i have just 2days to conclude on this project.
m4rk0
Re: best advice for this wireless link (point to point link)
Tue Oct 04, 2011 1:09 am
At first change "Country" to e.g. Germany, than Apply.
Do "Freq. usage"... Check on You antenna for what frequency range is made, 5100 - 5800? 5400-5800?
Update software to at least v4.17...
Set both RBs wlan1 to "Mode: bridge", try to turn of WDS... Bridge ether1 & wlan1 on both RBs...
How long is your wireless link? What are your antenna specs?
http://www.mreza-wisp.ba/
Please, give Karma if I fix your problem
Certified MTCNA
dunga
Wed Oct 05, 2011 1:00 am
Did change the country yet no changes
Frequecy = 5100 - 5800
Software updated to 5.6
The rb are in bridged mode, with wds turned on.
about 5km distance
15dbi
christyjame
Sun Feb 12, 2012 4:46 pm
Hi Seniors . . .
Thanks for this Post.
Christyjame
Users browsing this forum: No registered users and 26 guests
