rodolfo
Long time Member
Long time Member
Tuning point2point 802.11N, nv2
Wed Nov 02, 2011 9:21 am
Hi all.
In a 5GHz point-to-point, using good parabolic antennas, good cables, well builded radios (411AH+R52Hn) and placing correctly antennas, what are the parameters to try to tune?
I use this:
1. find a free frequency
2. set regulatory domain
3. play with antenna gain to calibrate output power
4. set data rate default with advanced rate selection
5. set hw retries = 7
6. set preamble mde = short
Leave the rest as default.
Are there other parameters (also not visibile from winbox) to try to tune to obtain a good link ?
rodolfo
IZ0UQV
n21roadie
Re: Tuning point2point 802.11N, nv2
Wed Nov 02, 2011 11:45 am
Site location is very important and proximity to other Wireless antenna's + what distance is the link is Freznel zone clearance between point A to point B OK,which polarity are you using H or V, use very short cables to the Antenna's, and is the antenna's dish or mesh grid, set the antenna gain in winbox to 0db
N21roadie,
Network 100% MT for Now?
rodolfo
Long time Member
Long time Member
Thu Nov 03, 2011 9:12 pm
thanks.
there are other parameters to tune in wireless interface to optimize a link (other than those listed)?
rodolfo
IZ0UQV
sup5
Thu Nov 03, 2011 9:40 pm
I usually use bridge <-> station-bridge and don't allow for data rates that require QAM64. Also I only use long guard interval.
I noticed QAM64 and the short Guard-Interval to be too risky to use (packet drops might occur, latency isn't stable!)
This means only the following data-rates should be enabled in custom-mode:
5Ghz-A:
6, 9 ,12, 18, 24, 36 Mbps
MCS 5-GHz-N:
0, 1, 2, 3, 4
8, 9, 10, 11, 12
I don't need the full sync of 270/300 Mbps.
IMO 162 Mbps on 802.11n with 2x2 Mimo is enough. This allows for 100Mbps half-duplex!
Everything that needs more throughput should be realised with licensed PtP-Links, or optical fibers.
rodolfo
Long time Member
Long time Member
Sat Nov 05, 2011 7:29 pm
thanks.
but guard interval is only for 802.11bmode or it works also for N?
rodolfo
IZ0UQV
Users browsing this forum: Google [Bot] and 37 guests
