rodolfo
Long time Member
Long time Member
Prblem in signal strength N,nv2
Thu Nov 10, 2011 5:30 pm
Hi all.
I have a 20km link, two 29dbi dish antennas, rb411ah, r52N.
I set bridge-station, antenna gain 0 in the two side.
I have this signal:
What can cause the signals asymmetry in the two chains ?
Normally, signal must be symmetrics ?
thanks
rodolfo
IZ0UQV
n21roadie
Re: Prblem in signal strength N,nv2
Thu Nov 10, 2011 9:37 pm
Have you tried moving the AP frequency and note if any changes in signal or CCQ.
N21roadie,
Network 100% MT for Now?
WirelessRudy
Fri Nov 11, 2011 1:12 am
Maybe cross connected the chains on both ends in regard to the duo polarity?
I mean, Side A: H-pol+CH0 and V-pol+CH1 and on side B:H-pol+CH1 and V-pol+CH0
If now the H-pol link has more path loss than the V-pol than we could have such differences?
I am only guessing but I have been wondering what would happen if I cross connect my 'n' links this way..
So please check this.
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
Users browsing this forum: No registered users and 33 guests
