gnuttisch
upgrade dual-nstreme
Wed Nov 16, 2011 1:04 pm
Hi
Today we have a dual-nstreme ptp link. And we want to upgrade it for higher speed.
Its running 433AH whit R5H cards and Jirous dual antenna.
Should we,
A)
Run one R5Hn card and two chains instead? and switch to Bridge-StationBridge
B)
Run two R5Hn cards and only one chain and keep the dual-nstreme config?
C)
Add one jirous antenna and run two chains in R5hn cards in dual-nstreme? possible?
Looking for very high speed to our high ground mast. who is the distribution point for several city's.
alexspils
Re: upgrade dual-nstreme
Wed Nov 16, 2011 4:43 pm
look at mimo 3x3, search in this forum, at screenshots troughtput is more than 300 mbps
cieplik206
Trainer
Trainer
Thu Nov 17, 2011 12:52 am
Best will be B
if you have good signal to other end you should be able to send 90/90 mbps full duplex while in dual nstreme you have only 36 something
https://www.wispcasts.com - Mikrotik Video Tutorials.
The best place where you can improve your skills!
Facebook - F/wispcasts
Twitter - @wispcasts
davidbinomix
Fri Nov 18, 2011 7:06 pm
One more option:
D) Run two R5Hn cards (only one chain) with ROS v5 and NV2 with ospf balancing ! (more redundancy, more speed).
Mode must be AP-Station (you can use NV2 security)
cieplik206
Trainer
Trainer
Sat Nov 19, 2011 12:15 am
Are you sure its more speed ?
davidbinomix
Sat Nov 19, 2011 2:53 pm
I mean, with the same conditions (tx/rx rate: 54Mbps/54Mbps, CCQ 100%/100%) best real throughput with nv2 + ospf dual
cieplik206
Trainer
Trainer
Mon Nov 21, 2011 11:24 pm
and you are using by that 40mhz channel and roughly have 108 mbps
While using N you can have on same channel width 300 mbps
So where is more speed come from ?
vladimirslk
Fri Nov 25, 2011 8:16 pm
addiditional question
Is it possible to use 2x R5hN on each side with RB433ah, 4 chains, or 4x4
Using dual polarity-dishes both sides?
How it's beeing configured like bonding?
gnuttisch
Fri Dec 02, 2011 6:05 pm
+1, can it be done?
Users browsing this forum: No registered users and 16 guests
