mahnet
Long time Member
Long time Member
IPTV/VOIP over Mikrotik
Tue Dec 13, 2011 4:30 am
Hi friends,
Has neone tried IP TV over Mikrotik. Getting over 80-100 mbps throughput over SXT shows me the way.
Can neone suggest some more on this.
I have tried things with IP Camera and VOIP. Just want to go a step further with IPTV.
Need a layout/design since I have no clue about IPTV.(I mean w.r.t the equipments being used for transmission/broadcasting)
Someone running it over cable can also suggest so I can take it a step ahead by replacing cables with pair of SXt's :)
Thanks,
perspetolis
Re: IPTV/VOIP over Mikrotik
Tue Dec 13, 2011 7:51 pm
hi
SXT 5HnD is a low cost, high speed 5GHz wireless device. Dual polarization 802.11n and Nv2 TDMA technology help to achieve even 200Mbit real throughput speed.
for more information go to this address: http://routerboard.com/product/108
Mohsen Farahani
MTCNA-MTCWE-MTCTCE
http://www.ipsolution.ir
ojsa
Wed Dec 14, 2011 10:10 am
You should look into a routed network with use of multicast to avoid wasting more bandwidth if you connect several users.
Tested all those things on the MTCINE course a couple of weeks ago and it was fascinating how the the routers avoid wasting bandwidth.
Network professional - Certified MTCNA, MTCWE MTCTCE, MTCRE, MTCUME and MTCINE. - Wiki Profile
mahnet
Long time Member
Long time Member
Wed Dec 14, 2011 6:06 pm
I mean can we go for IPTV over wireless with 100mbps throughput. How many IPTV clients can be catered with that much throughput.
chadd
Thu Dec 15, 2011 3:56 am
I don't see how you could deliver full blow IPTV over wireless, heck just a single HD stream from Netflix eats up ~4.5-5Mbps
mahnet
Long time Member
Long time Member
Thu Dec 15, 2011 4:53 am
Usually people will watch single HD stream at a time. So with 100mbit I can go for like 20 clients per SXT. Even if it is 15 clients, I guess it is worth. Terminating the SXT to a L2 switch and capping each port at 5mbps.
martini
Fri Dec 16, 2011 1:17 am
IPTV (multicast) works fine over wireless, but...
on 100M wireless link with good signal we can push 5-7 SD channels without frame drops, or one HD channel but with bitrate less than 15-20M.
So, for one clent its good solution ).
KbzA
Sat Feb 11, 2012 11:31 pm
Hi...
¿How can find manual, tutorial, books, for learn about IPTV using mikrotik?
I have RB1100AHx2, and, like it try in my PC using, for example, VLC.
Users browsing this forum: No registered users and 21 guests
