angboontiong
450Mbps...
Wed Dec 28, 2011 1:26 pm
Hi...
I saw there is the wireless connection can go up to the 450M/450M on with the AR9380 wireless card.
this information is from the China 2011 MUM presentation slide.
just want to know, it's this possible and what's the actual throughput we can have it?
thanks
InoX
Re: 450Mbps...
Wed Dec 28, 2011 1:30 pm
you are already looking at the picture, so it can be done and you can see the speed. :lol:
normis
Re: 450Mbps...
Wed Dec 28, 2011 1:34 pm
angboontiong why are you asking, if you already know the answer :D it's in the screenshot!!
angboontiong
Re: 450Mbps...
Wed Dec 28, 2011 4:38 pm
i believe this should in the indoor unit...
where can we get the 3T3R antenna?
if circular wave type, can they make it 3T3R on parabolic antenna?
searching mode now...
^_^
normis
Re: 450Mbps...
Wed Dec 28, 2011 4:44 pm
Matess
Re: 450Mbps...
Sat Sep 08, 2012 3:46 pm
Hi...
thanks
can you please post your setup? I have a link on a simillar hardware, but even when i have active all 3 chains the link speed is still only at 300Mb/s
Tbird
Re: 450Mbps...
Sat Sep 08, 2012 7:59 pm
And this as well: http://forum.mikrotik.com/viewtopic.php?f=7&t=62945
We are still testing our 3x3 antenna/enclosure concept and have seen up to 300 Mbps throughputs, but still facing issues with NV2 and disconnects. Like others have reported, 5.14 seems to be more stable – but we still have too much disconnects to move it into production and replace the 2x2 250 Mbps links. Maybe we’ll try 5.20 on AP and 5.11 on Station that some reports to be ok. Anyone else tried 3x3 and have version preferences?
TB
czolo
Re: 450Mbps...
Tue Sep 11, 2012 9:39 pm
TB
We have installed a few links in production environments. Most of them works now with 5.20, and we haven't any problems with disconnections. Max distances of our links is about 4km.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
Users browsing this forum: Baidu [Spider], jose and 29 guests
