kcallis
Correct hardware purchase
Tue Feb 14, 2012 10:10 am
I have been using my I7 laptop to connect my devices to ausb wireless client (ALFA Network) and the internal broadcom radio in adhoc mode to provide to the machines in my house. I have come to realize that there are better uses for an I7 machine. I would like to purchase a RB/433, and two N cards, and two antennas (one pointed to the distant AP, and one pointed internally, to either create an AP or adhoc connection.
Using the RouterOS 4, would the above work, or should I find another device to meet my needs. Thanks for any advice in advance!
brandonrossl
Re: Correct hardware purchase
Tue Feb 14, 2012 3:04 pm
Rb433ah
2 wifi cards
2 antennas minimum
Sounds like a winning plan to me.
kcallis
Tue Feb 14, 2012 5:06 pm
Rb433ah
2 wifi cards
2 antennas minimum
So I don't need to purchase a higher RouterOS version?
brandonrossl
Tue Feb 14, 2012 6:45 pm
ROS license level 4 and up will do you fine, 3 does not function as an access point (that you require).
kcallis
Tue Feb 14, 2012 6:58 pm
Thanks for the info... I will start looking at purchasing the equipment later today!
Users browsing this forum: bvandenbremt and 44 guests
