MUM Europe 2020
javadsh
Trainer
Trainer
limite number of wireless user
Tue Feb 21, 2012 1:13 pm
we have 3 Ap(with MT router) in a big hall . there are 600 0r more poeple here same time. and they want connect to our AP's. they are free in connect to every one. can we assign to an AP that only 50 user can connect to it and if another want to connect it .it block them or ... . at total every AP only have 50 user and if one user disconnect from AP and number of user be 49 user; another user can connect to AP.
krajnalic
Re: limite number of wireless user
Thu Feb 23, 2012 1:47 am
Yes, you can. In Advanced tab under Wireless, there is Max Station Count (default is 2007), change it to 50.
Or from console:
/interface wireless
set 0 max-station-count=50
where 0 is number of your wlan card, (maybe 1 or 2 if you have more than 1 card)
Dont forget to give karma
javadsh
Trainer
Trainer
Thu Feb 23, 2012 8:15 am
hi thanks.
this item is unchangeable. how can I change it?
christyjame
Sat Feb 25, 2012 8:25 pm
Hi Seniors . . .
Thanks for the useful post's answer. :o
Christyjame
javadsh
Trainer
Trainer
Sun Feb 26, 2012 12:37 pm
any one don,t know that how this option active?
cybercoder
Sun Feb 26, 2012 7:50 pm
Are you sure the router's wireless card is in AP-Bridge mode!?!?
Any sufficiently advanced technology is indistinguishable from magic. ( Arthur C Clarke )
Mikrotik certified consultant
Microsoft Certified Technology Specialist, Microsoft Certified IT Proffessional
http://www.netd.ir
brainy
Mon Feb 27, 2012 11:34 pm
Well, a problem is if you have several virtual APs ... the setting is not a global setting for the hardware interface :(
javadsh
Trainer
Trainer
Wed Mar 07, 2012 9:21 am
thanks.
my router was problem . this option is active in rb411 ah or license level 4 os
Users browsing this forum: marek263, Matta, nikaymhz and 35 guests
