angboontiong
Can the nv2 running on the x86 PC?
Wed Feb 22, 2012 3:18 am
Hi, i was plan to refurbish my intel P4 CPU for the link setup, as the P4 is higher speed than RB800...
Just wonder know, is the nv2 support in the x86 platform?
vik1988
Re: Can the nv2 running on the x86 PC?
Wed Feb 22, 2012 10:42 am
AFAIK, NV2 is a wireless protocol. If you are running some wireless card on mPCI slot like ath 5K/9K based then surely it will work. And yes u need ROS 5.0 onwards for NV2.
Vikas Kumar Gupta
If you Like my post then add KARMA
skype- kumarvikas_gupta
marioclep
Trainer
Trainer
Wed Feb 22, 2012 11:46 am
I've talked this for long time with some of the support guys.
Te fact is nv2 in x86 platforms (some vendors have their own hardware for AP devices running in x86 platforms) could work or not, but it is not guaranteed.
When trying to download ROS v5 for x86 the following note appears:
"Version 5.x x86 currently does not support Nv2 (requires RouterBOARD hardware). Nv2 for 5.x x86 may be supported in the future"
Regards
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
vik1988
Wed Feb 22, 2012 11:54 am
ohhh :shock: i haven't noticed that...Thnx Angboontiong for this info...
Vikas Kumar Gupta
uldis
Wed Feb 22, 2012 3:47 pm
you could check how it works in the latest RouterOS versions, as our Nv2 wireless protocol has been improved. But note that we don't guarantee how well it perform on x86.
Users browsing this forum: No registered users and 47 guests
