Roy
Ping Error
Wed Feb 22, 2012 3:28 am
Using 433GL, I test connect to CPE(AP).
192.168.1.12 PC can receive ping reply from all(192.168.1.1/2/11)
But 192.168.1.11 PC is only receive from 192.168.1.1. cannot receive from 433GL(192.168.1.2).
433GL is set as Station mode. ARP= Proxy ARP.
There is no Firewall setting.
Let me know what did I wrong?
vik1988
Re: Ping Error
Wed Feb 22, 2012 10:11 am
Why don't u try WDS mode...
have you configured Proxy-ARP on Common AP too...
Vikas Kumar Gupta
If you Like my post then add KARMA
skype- kumarvikas_gupta
0ldman
Re: Ping Error
Wed Feb 22, 2012 6:58 pm
WDS mode is dependent on the AP as well.
Station Pseudobridge may do the trick here.
What are you trying to do? Bridge a network? Just get on the Internet?
balimore
Forum Veteran
Forum Veteran
Re: Ping Error
Sat Feb 25, 2012 4:21 pm
nice and good suggestion
:wink:
Hasbullah.com
angboontiong
Re: Ping Error
Sun Feb 26, 2012 7:27 pm
can post you detail configuration?
cybercoder
Re: Ping Error
Sun Feb 26, 2012 7:32 pm
The standard 802.11 can't use to bridge with 802.3 ethernet, There's better use WDS Transparent bridge in replacement of psudo-bridge
http://wiki.mikrotik.com/wiki/Transpare ... o_Networks
you can use Dynamic Mesh and AP Bridge when you want to make bridge between more than 2 devices.
good luck
Any sufficiently advanced technology is indistinguishable from magic. ( Arthur C Clarke )
Mikrotik certified consultant
Microsoft Certified Technology Specialist, Microsoft Certified IT Proffessional
http://www.netd.ir
Users browsing this forum: No registered users and 39 guests
