cmurrayis
1.5km link issues
Sun Mar 18, 2012 2:39 am
Hi All,
I have just setup a link for a customer using a pair of RB411AH, Mikrotik > Mikrotik is doing 80mbps TCP using the test tool however from a windows machine running the iwndows BW tool I only see 40mbps tcp and this is reflecting the internet speed also which is topping out around 45mbps with a 100mbps connection on the other end.
I have check everything I can think of, CPU load on both devices is between 35 - 45% at 45mbps, If I plug in directly on the other end the internet connection is doing roughly 120mbps.
http://dl.dropbox.com/u/8790688/mikrotik.PNG
Any pointers? or suggestions.
Cheers
Cameron
czolo
Re: 1.5km link issues
Sun Mar 18, 2012 12:46 pm
Hi All,
Cheers
Cameron
In Btest window, change TCP Connection Count to 1, and make another test. Put results here, then I can explain you why the results are like you descibed.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
cmurrayis
Sun Mar 18, 2012 2:26 pm
So I changed it from the default of 10 to 1 and got a similar result:
http://dl.dropbox.com/u/8790688/Mikrotik1.PNG
and as you can see a similar result for the traffic to the internet: http://www.speedtest.net/result/1841278263.png
0ldman
Sun Mar 18, 2012 4:07 pm
What is your CCQ? Signal strength? Have you tried a different channel?
Any firewall or mangle rules? Queues?
czolo
Sun Mar 18, 2012 4:57 pm
Now everything looks like it should. `
TCP traffic needs ACK pacekts. Single session throughput strictly depends on RTT, MTU, and errors in transmission (BER).
Problem is described here: http://www.cost285.itu.edu.tr/tempodoc/ ... otorti.pdf
In wireless links the most important thing is BER. If you have to many errors in your link, it affects session throughput. Programs which use many TCP sessions for testing will show better result, than one session check. Default MT use 20 simultaneous sessions, and web tests use one session for checking.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
cmurrayis
Sun Mar 18, 2012 11:40 pm
czolo
Mon Mar 19, 2012 12:48 pm
Poor CCQ, bad signals - check antenna system.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
0ldman
Mon Mar 19, 2012 11:31 pm
Even that is not really clear. Was the link under any load at the time?
cmurrayis
Mon Mar 19, 2012 11:36 pm
Ok so I switched one of the chains around as it was mismatched and tried to align the antennas a little better and now it looks like this: http://dl.dropbox.com/u/8790688/Mikrotik3.PNG
czolo
Mon Mar 19, 2012 11:53 pm
What antennas do you have there? -59 on one chain, and -72 on second... it looks like antenna problem.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
cmurrayis
Mon Mar 19, 2012 11:59 pm
czolo
Tue Mar 20, 2012 12:22 am
Antennas are almost perfect, so it have to be something else. Maybe a card, or pigtail.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
andressis2k
Tue Mar 20, 2012 2:05 am
Are the antennas well aligned?
Maybe you may check vertical alignment on both sides.
If a dish is a little rotated, the cross polarization attenuation will decrease a lot, and CCQ will reduce on consecuence.
I recommend you use a bubble level to check
If you can find the video, there was a conference in the last MUM that explained this
Regards
cmurrayis
Tue Mar 20, 2012 2:07 am
MUM last week?
andressis2k
Tue Mar 20, 2012 3:21 am
MUM last week?
Yes. If I remember well, that conferenced was exposed by Deltalink
Regards
cmurrayis
Wed Mar 21, 2012 2:21 am
So I havent had a chance to check the antenna at the primary site yet so I switched the AP to send on the good Signal/Condition Chain and recieve on the misaligned chain and the ClientAP the oposite as below:
http://dl.dropbox.com/u/8790688/Chains.PNG
As you can see the Signal and CCQ is now perfect for the recieve chain:
http://dl.dropbox.com/u/8790688/signal.PNG
However we are still only able to on 1 connection get 35 - 45mbps and 4 connections we get 75mbps/100% cpu
http://dl.dropbox.com/u/8790688/1%20stream.PNG
http://dl.dropbox.com/u/8790688/2%20stream.PNG
http://dl.dropbox.com/u/8790688/4%20stream.PNG
So Any ideas how with 100% CCQ and 150mbps on the chain 100% of the time how to achieve a higher single TCP session throughput?
Cheers
andressis2k
Wed Mar 21, 2012 10:55 am
Are you running btest into the same AP?
It eats lots of CPU, and that decreases perfomance.
You may use another board in each side, or 2 computers running btest
Regards
cmurrayis
Wed Mar 21, 2012 1:46 pm
Hi
I'm running the test from a windows machine behind the client out a 100mbps connection on the ap side. No routing is being done by the units. CPU load is roughly 33% when doing the external speed test and getting 45-50mbps these results are matched if I do a Btest from windows across the link to the ap yet client to ap gets 80mbps.
Cheers.
andressis2k
Wed Mar 21, 2012 3:14 pm
If you make btest between computer and same side AP.... do you get 90mbps?
Maybe your ethernet cable is too long.... or it's damaged
Regards
czolo
Wed Mar 21, 2012 11:20 pm
Cheers
Remember that TCP i a protocol that use duplex connections. It sends ack, so making one side ccq better can't solve 100% of your the problem.
What can you do then :p ?
Try to set data-rates maualy for one step lower than a max from auto. In example - if your link is now working with max MCS7, set manually rates to MCS1-MCS6.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
cmurrayis
Wed Apr 25, 2012 3:24 am
So after all this time the link is still running at -51 both chains 100% ccq and 300/300 yet a single TCP session can only do 50mbps. Have tried routing, bridging and tunnels and all the same result.
Users browsing this forum: Bing [Bot] and 53 guests
