MUM Europe 2020
gabrieldeloeste
THE BEST HARDWARE TO GET 80Mbps AT 31KM PTP LINK
Sat Mar 24, 2012 11:57 pm
At this time, what is the best hardware and configuration to obtain a ptp link (up+down) of 80 mbps. I had made links with RB433ah+r52ah dual polarization with 30dbi antenna and only had obtained aprox 25mbps agregate.
ricky011
Re: THE BEST HARDWARE TO GET 80Mbps AT 31KM PTP LINK
Sun Mar 25, 2012 10:15 am
the most I got, on a similar setup, but at 70km PtP link, is cca 60mbit real throughput unidirectional... you must have excellent signal, and find a non congested channel, with CCQ over 90, preferably... although, I was using rb411ah, 600mW ubnt minipci, and 32dB dualpol parabolic antenae...
mahnet
Long time Member
Long time Member
Sun Mar 25, 2012 10:51 am
r52h is a single pol minipci . use r52hn for dual pol antenna and u have 2 chains.
height needed should be more than 200 ft from ground level.
gabrieldeloeste
Thu Mar 29, 2012 11:20 pm
Sorry : I used r52hn,,,,, ricky011: what model of ubnt mini pci have you used?
mahnet
Long time Member
Long time Member
Fri Mar 30, 2012 5:35 am
use r5shpn mini pci. it is a 800mw card. should give u ample power.
popcorrin
Sat Mar 31, 2012 4:02 am
That card is single chain though, he won't be able to get the throughput he needs with that.
gabrieldeloeste
Sat Mar 31, 2012 7:55 am
At what do you suggest to get this througput?
popcorrin
Sat Mar 31, 2012 8:27 am
Actually the R52HN is going to give you about as good as chance as any to reach that kind of throughput. If you could use some dishes with higher gain that would help.
Also, you didn't give details on your configuration. Are you using 40mhz channels? Are you using nstreme or nv2? You are going to have to use one of these protocols to get anywhere near that kind of throughput. Like ricky said, you are going to have to make sure you are on a clean channel and make sure you have your antennas aligned perfectly.
With that said, 80Mbps duplex is going to be a tall order at that distance. You might want to look into some licensed gear if you absolutely need that kind of throughput.
Users browsing this forum: No registered users and 18 guests
