ddenia
WDS or VPLS for Mikrotik?
Wed Apr 18, 2012 9:40 am
Recently used the WDS, but noted that it is less fast, and then decided to try VPLS and noticed that it is faster ... Like it or not? and what do you recommend I use?
sup5
Re: WDS or VPLS for Mikrotik?
Wed Apr 18, 2012 1:50 pm
use station-bridge instead.
much easier to setup.
angboontiong
Wed Apr 18, 2012 2:01 pm
what's the different station-wds and station-bridge.
any much different on it?
thanks.
rodolfo
Long time Member
Long time Member
Wed Apr 18, 2012 3:05 pm
I think wds is an apple and vpls is a table.
completely different things to answer your question.
could you explain what do you want to achieve ?
rodolfo
IZ0UQV
ddenia
Thu Apr 19, 2012 11:23 am
I need so that the base station connected to 10 clients, and so they each received a 20-50Mbit.
sup5
Thu Apr 19, 2012 1:59 pm
use 'ap-bridge' on your access-point
use 'station-bridge' on your clients
there is no need to mess around with WDS, EoIP or even VPLS.
They all add complicated configuration and in case of EoIP and VPLS unnecessary overhead.
Hotz1
Thu May 03, 2012 3:14 pm
What if you need both ends to be ap-bridge? (e.g., backhaul radios that connect to each other as well as to others.)
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
Users browsing this forum: No registered users and 16 guests
