czolo
180Mb TCP FDX with MIMO 3x3
Wed May 09, 2012 5:55 pm
Hi
I managed to get amazing transmission results results with 3x3 hardware.
Here is sample:
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
0ldman
Re: 180Mb TCP FDX with MIMO 3x3
Wed May 09, 2012 6:11 pm
Nice!
Fumi
Wed May 09, 2012 7:23 pm
Nice!!
What radio use? board? What kind of test use?
I do test with iperf half duplex TCP and I can reach 300mbps
czolo
Wed May 09, 2012 7:43 pm
Nice!!
It was tested with MT Btest on Atom motherboard.
Here is a full review. It will be translated to english, but now it's only available in polish.
http://www.cyberbajt.pl/raport/475/
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
0ldman
Wed May 09, 2012 10:18 pm
What board are you using?
I was leaning towards an Atom board just for mini PCIe, still come out cheaper than an RB800.
server8
Thu May 10, 2012 10:37 am
What kind of antenna do you used?
czolo
Thu May 10, 2012 10:55 am
I'm using this antennas:
http://www.cyberbajt.com/en/shop_item/3 ... o_3x3.html
More info is on their polish site:
http://www.cyberbajt.pl/produkt/4332/
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
czolo
Thu May 10, 2012 11:06 am
I'm using Intel DN2800MT motherboard:
Here is a comparison of motherboard perfomance:
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
macgaiver
Thu May 10, 2012 11:34 am
Ehm, your result table is completely off - i just run simple test Trough my RB493G - that have some configuration on it and with single TCp connection to my linux server i got more than 300Mbps throughput. I''m sure if i will clear up configuration and will make more TCp connections i will get even more.
Only way i can see you can get these results is if you run test to or from the router or run loopback to itself.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
normis
Thu May 10, 2012 11:39 am
Loopback results are meaningless, they only show that the ATOM has more CPU Cache. See what Macgaiver said above. Correct TCP test procedure will give good results on RouterBOARD devices.
czolo
Thu May 10, 2012 11:49 am
OK - I will check it.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
czolo
Thu May 10, 2012 11:50 am
Yes - it's loopback test. On the router I make BTest to loopback (127.0.0.1)
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
spawnhell
Thu May 10, 2012 12:55 pm
You did test to linux platform so you had to use Ethernet connection. RB493G has a switch port.
If you do this you are not testing the processor of the platform it self.
Do fdx TCP test to your linux server and post the results.
macgaiver
Thu May 10, 2012 3:37 pm
It was routing test, so all traffic went trough CPU. port--switch1--CPU--switch2--port to be exact.
it was FTP download.
czolo
Tue May 29, 2012 11:44 am
I think it may interest some forum users:
https://www.cyberbajt.com/en/news/6/0/mimo_3x3.html
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
normis
Tue May 29, 2012 11:54 am
Interesting tests. Here is our test of 3x3 MIMO on RB800:
Taken from here: http://mum.mikrotik.com/presentations/P ... 012-PL.pdf
Like macgaiver pointed out above, TCP loopback test is very misleading and doesn't show actual performance. You would need to test through the device with actual traffic, or iperf.
Further on in the article they show that doing this actually gives good results, as opposed to loopback test.
karlos
Wed Jun 06, 2012 12:46 pm
Sory Normis, but Btest results are for me meaningless. We made some p2p 2+2Mimo links showing Btest results over 200Mbits but the normal trafic was around 50-70Mbit, using 1+1chain Btest shows 100+Mbits and real performance 90+Mbits ..........
So right now we are preparing brand new p2p link, using the brand new Jirous JR S24-MIMO antenas
, using brand new 433GL and brand new R52Hn cards, so lets see how it ends.
Ill report the results.
This is the best hardware what i can use from Mikrotik on this place, so i hope for some reasonable performance.
normis
Wed Jun 06, 2012 12:48 pm
Karlos, what do you mean by "normal traffic"? many programs don't actually utilize the maximum possible speed. you could test with multiple FTP connections
karlos
Wed Jun 06, 2012 2:20 pm
Yes, to test normal traffic we use just normal PC using normal multiple http or ftp transfers.
We found some places in our network that work very good using nv2 but the same setting wont work on another location. We also have one very strange location unable to use 802.11n at all, but 802.11a works great. This is not always about noisy area, nearly no traffic in the air, but N does not work at all. We changed antenas, boxes, cards, boards, pigtail..... nothing. But we have some another places and found that 802.11N using normal modulation works pretty slow, but nv2 improoves transfer rate 3times. It really deppends on location more than another factors.
But like i promissed, ill give results on this brand new p2p link. (Coplete signal levels, settings, speeds, loads, distance etc...) Please wait for it.
karlos
Wed Jun 06, 2012 5:55 pm
Card rates Fixed do 15dBm
Distance 1800m
Signal Strenght -50/-50dBm
CCQ 97/96%
Rate 300/300Mbps
Frequency 5500Mhz
Band 5GHz only N
40MHz width
protocol nv2
Datarates advanced
0+1chain
HT AMPDU 0+4
HT guard ANY
lowering card power will cause lowered transfer rate
more card power will not help but does not hurt the transfer rate or CCQ, its just useless
I also found that the "wanted" power is not the output power of the card. So i started with maximum power (default) and than lowered the output using signal RX strenght on other side of the link. We need to stay under 30dBm (or pretty near to that value)
BTest UDP MK 2 MK direct just over the wirelles 125/105Mbit simultanously and pretty stable. (230Mbit agregate) CPUs still not on 100%load
Normal test using Notebook
One stream http data average 37Mbit max 45Mbit
Five streams http data average 65Mbit max 76Mbit
So is it ok ? Or is something wrong ?
Thank you
czolo
Thu Jun 07, 2012 2:41 pm
What is CPU usage when you are doing tests from laptops?
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
karlos
Thu Jun 07, 2012 3:05 pm
RB has 20-30% load, so CPU is boring ;-) coz the new RB433GL works on 800MHz at default.
karlos
Thu Jun 07, 2012 4:18 pm
And i made another test:
433AH running Btest <-ETH-> 433GL <-nv2 MIMO 2+2-> 433GL <-ETH-> 1100AH Btest Server
Running UDP test in both directions nearly to 100Mbit in both ways, just limited by 433AH 100Mbit port and also CPU on 433AH was on 100%load. Load on 433GL was cca 70%.
But this is still just test, not real data transfer.
Matess
Mon Aug 27, 2012 9:44 pm
I have a link on 500m with 3x3 mimo on 80cm offset dishes. Wireless cards are Compex WLE300NX 6A.
Runing in 20MHz channel and a real speed is about 95Mb/s. (tcp test shows the same)
Weird thing is link speed. It says just 144Mb/s... I thought it will be just a little under half from 450Mb/s....
czolo
Tue Oct 09, 2012 8:07 pm
I noticed that there is a new version of 3x3 link in Cyberbajt:
Nice thing is gigabit PoE with Atom board. Interesting that on the image there is no RAM in the board :)
As soon as I get a chance I will try to test it and report here results.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
Users browsing this forum: No registered users and 19 guests
