ViREnG
[Req - SOFTWARE] Create Coverage Map of Wireless Netwrok
Thu May 31, 2012 10:48 am
Hello Friends
How can I create a Wireless network coverage for my network , I have a medium size of Wireless network on 2.4Ghz & 5.8Ghz Freq with about 18 Site (about 150KM^2)
I want create a Coverage map like This website : http://www.mywificoverage.com/ <-- This site is free for create just one site
Anyone know a better software like above link to create a coverage map without test in each zone ?
Muqatil
Trainer
Trainer
Thu May 31, 2012 12:15 pm
I successfully male a coverage map of My network using and tweaking radiomobile. The accuracy is very close to reality. It takes a while before RAdiomobile gets configured, but There are a lot of guides around. And it's free
Renato Bernardi
skype: medtech5
ViREnG
Re: [Req - SOFTWARE] Create Coverage Map of Wireless Netwrok
Thu May 31, 2012 6:03 pm
Don't support 2.4 and 5.8Ghz :? and don't have flat antenna or sector antenna ... !!?
anyone have a better solution ?
slech
Long time Member
Long time Member
Thu May 31, 2012 9:49 pm
sorry for my english
Muqatil
Trainer
Trainer
Fri Jun 01, 2012 12:05 am
It does support from 100mhz to 30ghz, you have to configure it to match you needs and your specifics.
A perfect "out of the box" software which is free doesn't exist. A lot of commercial version (which are a copy of Radiomobile) are out and they have the templates you are looking for.
Renato Bernardi
skype: medtech5
normis
Fri Jun 01, 2012 12:24 pm
Nearly all commercial tools that you will find, are actually using Radio Mobile as the calculation engine. I think it is the best. It supports all frequencies, including 2.4 and 5.8GHz
fgoldstein
Tue Jun 19, 2012 6:28 pm
One thing to note about MyWifiCoverage and RadioMobile -- they're basically the same thing underneath. RadioMobile is the free product. It's incredibly powerful, but takes some time to learn and to get the settings right for your application. MyWifiCoverage is the new pay-to-use version by the same author. It is easier to use, but can get expensive for a large network. It doesn't necessarily create a more accurate map, though, since it uses the same underlying mechanisms, which are based on the Longley-Rice propagation model and the SRTM topo mapping data.
Credit to Roger, though, for doing this all for free for so many years, only recently trying to really monetize it, in partnership with another supporter of the WISP community.
Boo
Wed Jun 20, 2012 6:42 pm
This one works well but doesn't calculate for you, would be a lot of foot work with it.
http://www.netspotapp.com/
normis
Thu Jun 21, 2012 8:50 am
you are right that it uses radiomobile underneath, but the authors are not related. mywificoverage is made by one of our distributors, Link Technologies.
Tbird
Sat Jun 23, 2012 6:01 pm
For other antenna patterns - have a look here: http://forum.mikrotik.com/viewtopic.php?f=7&t=10092
Many seems to use UBNT antennas, and they can be found here: http://www.ubnt.com/support/patterndata
As in many aspects of life - there is no way around reading and learning. In my perspective - RadioMobile is priceless, but you have to learn it first. I especially like the export functions and the ability to make Google Earth overlay-files for coverage display - like these:
Users browsing this forum: Google [Bot] and 51 guests
