marKowisp
Nstreme,NV2,802.11 for a PtMP
Tue Jun 19, 2012 2:43 am
We need create a new WISP but.. (in mind) but for a high number of subscribers per sector.
What is the best protocol for a ptmp?. Nstreme, NV2, 802.11? the configuration would be in 5Ghz with 60 degree sector antennas horizontally polarized.
You need to have a maximum of subscribers with bandwidths + / - 2Mb each
Thank you,
rodolfo
Long time Member
Long time Member
Re: Nstreme,NV2,802.11 for a PtMP
Tue Jun 19, 2012 10:11 am
today is nstreme, tomorrow will be nv2.
the maximum number of users for sector is not a protocol problem.
often is a problem of:
- noise
- antenna model
- radio device model
- site setup
- type of cpe
- accuracy of cpe setup and tracking
rodolfo
IZ0UQV
n21roadie
Tue Jun 19, 2012 12:25 pm
Thank you,
How many per sector?
NV2 will give you more clients per sector,
Why horizontal polarity as usually it's vertical for PtMp,
N21roadie,
Network 100% MT for Now?
marKowisp
Tue Jun 19, 2012 3:25 pm
+/ 80-100 per sector in mind
Horizontal Pol. is selected because vertical polarization is used in many devices in the site, the horizontal is unused.
n21roadie
Tue Jun 19, 2012 4:25 pm
80 – 100, depending on actual customer daily usage but typically careful bandwidth limiting will be required, for example what I have done is to offer higher speed during normal daytime business hours 7am to 5pm (say 3Mbit) but during peak usage hours 5 to 10pm reduce it to 1Mbit, with ; http://wiki.mikrotik.com/wiki/Limit_Dif ... _and_Night
If there are many other devices on site then you will have to use AP's with good RF screening and placement is critical to reduce pick-up of other signals from these other devices on site, otherwise NV2 which will give more clients per AP and prevents hidden-node issues maybe effected by disconnects.
N21roadie,
Users browsing this forum: Bing [Bot] and 36 guests
