Ivoshiee
Superchannel is not working or am I doing it wrong?
Tue Jun 26, 2012 1:44 am
Does the superchannel work for anyone on v5.18?
It seems not to work between my SXT 5HnD and RB411AR running R52nM. I'll get no radio link if I put in any listed, but arbitrary frequency, but I get radio link as soon as I put in any default link frequency value (listed with bold font under WinBox). Either AP side is not sending anything out or client side is unable to transmit/receive in arbitrary frequencies (by it's status it is not scanning every available frequency and is only hopping around default frequencies).
Note: Both sides are running v5.18, country code is set "no_country_set" and both ends are set to the same frequency.
Is superchannel not functional anymore or what am I doing wrong?
normis
Re: Superchannel is not working or am I doing it wrong?
Tue Jun 26, 2012 2:11 pm
please post output of the command "/export compact" so we can see your configuration
0ldman
Tue Jun 26, 2012 6:41 pm
Have you changed the scan list to include your new channels?
Ivoshiee
Wed Jun 27, 2012 12:23 pm
I haven't done that. How to do it?
normis
Wed Jun 27, 2012 12:24 pm
/interface wireless set wlan1 scan-list=5500-5800
substitute 5500-5800 to the frequency you will use
Ivoshiee
Thu Jun 28, 2012 12:33 am
Thanks. It did the trick.
Users browsing this forum: No registered users and 37 guests
