MUM Europe 2020
mag
q: simultaneous 2.4 and 5.2 GHz
Thu Jul 05, 2012 12:51 pm
I couldn't find a solution by searching and the question might also be of interest for others, so I am asking it here:
Many WLAN-routers/IADs allow simultaneous use of WiFi 2.4 and 5.2 GHz. However, only the usual 2 antennas are build on these devices.
Would it be possible to implement that with a RouterBoard (e.g. RB/493)? It is clear that there have to be two radio cards on the RouterBoard each for one frequency in use.
But how could one connect the two radios (= 4 antenna cable) to only 2 antennas? According to my limited understanding of RF, a kind of "mixer" should be possible with appropriate wideband antennas (2.4 and 5.2 GHz).
A little picture is attached.
Or is there a MT supported WiFi radio which could simultaneously use 2.4 and 5.2 GHz?
I hope the objective is understandable and I would appreciate any hints.
TIA
acim
Re: q: simultaneous 2.4 and 5.2 GHz
Sat Jul 07, 2012 11:29 pm
Why do you think two radios have to be connected with four cables to 2 antennas? That's only the case if you use MIMO antennas.
mag
Mon Jul 09, 2012 11:41 pm
Sorry, forgot to make that point clear: yes, MIMO (2x2) should be used.
(Otherwise it would be a bit trivial ;-)
samsung172
Tue Jul 10, 2012 12:28 am
its possible (but not advised) to do with a "T splitter". Ive seen som installations, using T splitter to do just this. (also 2 X 5Ghz band on 1 antenna). U will get "Some" signal.
krakenant
Tue Jul 10, 2012 5:17 pm
The question marks are called diplexors, they split different frequencies into different lines, commonly used in the coax and satellite world.
samsung172
Tue Jul 10, 2012 10:36 pm
I have seen it done with old fashon BNC T splitter from old coax network age. :P (And yes. it was working)
Users browsing this forum: dolber, heidarren and 35 guests
