MUM Europe 2020
shielder
Couldn't change channel on AP
Tue Jan 17, 2006 2:35 pm
Hi, here's my configuration
name="Radio" mtu=1500 mac-address=00:0C:42:05:01:53 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name="Solusindo Bintang Pratama" mode=ap-bridge ssid="Solusi"
area="" frequency-mode=manual-txpower country=indonesia antenna-gain=16
frequency=2412 band=2.4ghz-b/g scan-list=default rate-set=configured
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps
basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps
max-station-count=1024 ack-timeout=dynamic tx-power=30
tx-power-mode=card-rates noise-floor-threshold=default
periodic-calibration=enabled burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=yes security-profile=default
disconnect-timeout=10s on-fail-retry-time=100ms preamble-mode=long
compression=no
I have 38 clients on this AP, and when i change the channel, my client couldn't associated with my AP. I have to go back on channel 2412 for my client to associate with my AP. What's wrong with my configuration? Would someone please tell me? Thank you.
cibernet
Long time Member
Long time Member
Re: Couldn't change channel on AP
Tue Jan 17, 2006 10:29 pm
compression=no
Interference?
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
djape
Wed Jan 18, 2006 3:43 am
Probably noise.
Did you try to change channel and then restart MT to see if clients connect?
Cheers...
I drink like a pirate and smoke like a hippie...
shielder
Wed Jan 18, 2006 5:08 am
Yes, i have change the channel and restart (soft restart from software) MT, but still no connection from my client. If i use another AP (smartbridges or alcon), it works fine on that channel. Do i need to restart the power of MT?
jarosoup
Long time Member
Long time Member
Wed Jan 18, 2006 5:32 am
I don't know if this will help at all, but the above should be:
basic-rates-b=1Mbps
djape
Wed Jan 18, 2006 11:33 am
Personally I never saw the difference between these two.
cibernet
Long time Member
Long time Member
Wed Jan 18, 2006 11:47 am
Check the pigtail, antenna, search for water in the connectors, check minipci card
José Ignacio Acosta
Mikronet
mikapojic
Wed Jan 18, 2006 9:24 pm
Try to set ack-timeout to 408, it could help. and try tx power to default.
Users browsing this forum: maurodx and 22 guests
