huigezi
ROS SXT and ubnt In contrast to delay
Thu Aug 02, 2012 4:04 am
ROS delay than the UBNT gap is too big
If you want knowledge, you must toil for it
hossein
Re: ROS SXT and ubnt In contrast to delay
Thu Aug 02, 2012 8:11 am
it is because of different parameters that cmd uses for ping and what mikrotik does.
huigezi
Thu Aug 02, 2012 8:19 am
I want to say
use nv2 of mikrotik is get high delay
and use ubnt it'is not this ping delay
taduikis
Thu Aug 02, 2012 9:24 am
Nv2 ping times are higher, try using nstreme instead. But yeah, it's sad ubnt outperforms MT with TDMA :(
n21roadie
Thu Aug 02, 2012 12:01 pm
I often wonder is the higher ping times on NV2 due to all the stuff the Mikrotik has on each device even after removing unneeded packages, could it be a processor issue and is there lower ping times with a faster processor?
N21roadie,
Network 100% MT for Now?
InoX
Thu Aug 02, 2012 1:46 pm
no tdma for ubnt in that picture
linek1980
Thu Aug 02, 2012 4:29 pm
tdma UBI
0ldman
Thu Aug 02, 2012 7:11 pm
Agreed.
It isn't a valid comparison to use TDMA on one and not the other.
InoX
Thu Aug 02, 2012 9:27 pm
tdma UBI
airmax is disabled, so no tdma :)
Polky
Thu Aug 02, 2012 10:17 pm
I would prefer to test the functionality. NV2 is useless in most cases. UBNT beat MK, both in response and in functionality.
taduikis
Fri Aug 03, 2012 1:55 am
Yeah. And that is sad. It seems that they need so little to make their already great product just perfect..
n21roadie
Fri Aug 03, 2012 11:15 am
I find NV2 very good it will be better when latency is reduced and is far for useless.
N21roadie,
Users browsing this forum: No registered users and 24 guests
