vahid023
Very Low CCQ!! help me
Fri Aug 10, 2012 2:51 pm
hi
please see attached image
distance is only two meter
whats the problem in tx rate?
normis
Re: Very Low CCQ!! help me
Fri Aug 10, 2012 2:53 pm
your signal is much too strong (-32). try to increase distance to get tx power -50 or -60
vahid023
Fri Aug 10, 2012 3:02 pm
i tried tx power from 5 dbm to 17 and then default with no change.
i tried distance about 2 kilometer with no change
only when i enable just G and 54Mbps speed and disable all modes and speed the problem will solved and ccq=90 to 100
but my network is ptmp and i want good ccq and speed for clients that have good signal
normis
Fri Aug 10, 2012 3:03 pm
post an image when your Tx power will show -60
vahid023
Fri Aug 10, 2012 3:41 pm
this is another AP
I forced to check good speeds and uncheck low speeds to increase ccq and speed
vahid023
Fri Aug 10, 2012 3:45 pm
and enable just G mode.
normis
Fri Aug 10, 2012 3:51 pm
I don't see CCQ in those images. What do you consider "bad CCQ"? What values do you get when signal is -60?
n21roadie
Fri Aug 10, 2012 5:08 pm
Why have "uspecified" wireless protocol on the AP?
N21roadie,
Network 100% MT for Now?
vahid023
Fri Aug 10, 2012 11:55 pm
n21roadie: i dont know.whats the problem?
n21roadie
Sat Aug 11, 2012 1:52 pm
I thought there was a screenshot of the AP on this post but on checking i don't see it, so maybe i confused this with another post which may have been opened at the time - sorry :?
N21roadie,
vahid023
Sun Aug 12, 2012 11:48 pm
i checked again and see that speed and ccq goes up after afew minutes
n21roadie : yes,i removed it because of my visible SSID.
n21roadie
Mon Aug 13, 2012 11:55 am
Ok - You removed the screenshot of AP :o
If you are using on a AP a wireless protocol of "unspecified" this could confuse the CPE as it tries to decide which protocol to use, I use on all CPE’s “NV2, Nstreame, 802.11” on the AP I use select NV2 or Nstreme or 802.11, I never use “any” and no problems with network
N21roadie,
vahid023
Mon Aug 13, 2012 2:36 pm
thank you my friend.
Users browsing this forum: Manueloloo and 39 guests
