alzeno
Wireless Model
Wed Sep 12, 2012 3:46 pm
Hi, I want to broadcast internet using wireless broadcast device. The client will receive the service by his laptop.
Which Mikrotik wireless model I should choose for doing this?
The covered area is about 200-400m.
A friend in need, is a friend indeed
rodolfo
Long time Member
Long time Member
Re: Wireless Model
Wed Sep 12, 2012 8:20 pm
it depends on the number of concurrent clients attached to one access point and bandwidth you want to deliver to users
rodolfo
IZ0UQV
troy
Re: Wireless Model
The GrooveA combined with a 5db omni antenna would probably be the least expensive to start with, but any MT device with a Level-4 license will work.
400m is too much for a laptop though. You'll be lucky to get 40m indoors and 90m outdoors. In an outdoor network, a laptop might see an AP from 2-3km away, but it will not be able to associate. You can probably get a little more distance with a larger antenna, but not much. The laptop is still the limiting factor.
To cover a 400m radius for laptops in an outdoor environment, you're probably looking at 35-40 access points. Indoors, it's much more, depending on the layout and materials in the building, it could be as many as 150 or more.
-Troy
alzeno
Re: Wireless Model
Thu Sep 13, 2012 1:29 pm
Hi Troy, what you suggest me to do if I want to broadcast Internet in about 200m radius?
1-Use an omni antenna with GrooveA?
2-Use a USB external modem for Laptop clients?
Another question, I read in Mikrotik website "The Groove 5Hn has a RouterOS Level3 license, so you can use it as a wireless client or for point to point links.", can I use it as a wireless broadcast station for clients?, and is there a larger Mikrotik model that can I use it?
Thanks in advance
alzeno
Re: Wireless Model
Thu Sep 13, 2012 2:01 pm
What about Wideband 10dB Outdoor Omni Antenna, and StationBox Mikro Enclosure with 5GHz 15dB MiMo Antenna?, do you think that they are suitable for me?
troy
Re: Wireless Model
Thu Sep 13, 2012 3:12 pm
The system/antenna you choose will make little difference. 2.4/5.8 will not make a huge difference either when it comes to providing access to laptops and other consumer devices. They all have a limited range.
I mention the groove only because it's a very low cost solution and available in either L3 or L4. In terms of antennas, you can stick anything you want on them with any appropriate connectors/adapters.
Users browsing this forum: No registered users and 35 guests
