Antixx
Very very Low signal with RB751U-2HnD
Sat Sep 22, 2012 7:53 pm
I have RB751U-2Hnd it had good strength of signal but suddenly i see very low signal in even 8 meter it has very low signal on my laptop,
what is the problem anybody have suggestion?
best regards,
Antixx
Re: Very very Low signal with RB751U-2HnD
Sun Sep 23, 2012 9:30 pm
Anybody there? Please let me know what is the best way to solve this problem.
The signal is very very low!!!
I did reset factory but the problem is still exist.
Sent from my GT-I9300 using Tapatalk 2
normis
Mon Sep 24, 2012 9:50 am
Send your supout.rif file to support@mikrotik.com, we will check status of your device.
mobile4lte
Fri Sep 28, 2012 6:42 am
You can choose external antenna, choose a 3 -7 db is enough, big bad instead.if you want to know or choose more some antenna,you can visit the website:http://www.mobile4wifilte.co.uk/
Antixx
Sun Sep 30, 2012 5:30 pm
Something happened to RB it was very good. It is not right way
Users browsing this forum: No registered users and 53 guests
