Cetalfio
SOLVED! hide-ssid=yes
Tue Oct 02, 2012 2:50 pm
maybe a bug in version 5 of ROS when I set the AP interface with idden ssid /interface wireless> set hide-ssid=yes and do a scan networks with a CPE I still see the ssid why?
cetalfio
sytex
Trainer
Trainer
Re: hide-ssid=yes
Tue Oct 02, 2012 3:44 pm
I think you only see it, when this SSID is set in the cilent/CPE device.
uldis
Re: hide-ssid=yes
Tue Oct 02, 2012 4:44 pm
what wireless-protocol you use on the AP, maybe you use Nv2 as that doesn't support hide-ssid feature.
Cetalfio
Re: SOLVED! hide-ssid=yes
Tue Oct 02, 2012 6:57 pm
Sure protocol is NV2, solved it.
2jarek
Wed Oct 10, 2012 1:31 am
5.20 802.11n no NV2 same. hide ssid not work.
Users browsing this forum: misha and 98 guests
