DogHead
RB433UAH w/RB52H miniPCI slot problem
Wed Oct 03, 2012 2:54 am
We are trying to run OpenWRT on an RB433UAH with two RB52H (AR5414) modules on it. The enclosure we are using requires that we use the top two miniPCI slots. Can't change the enclosure and we can't fit a module in the bottom slot.
We are using the ath5K driver with mac80211 under kernel 3.2.5.
One radio is being used as an AP on 2.4GHz and the other is using AdHoc mesh using batman-adv. When we put the radios in the bottom two miniPCI slots all is well and the mesh works and the AP works. But...
When we move the radio from the bottom slot to the top slot, we lose radio signal from it. It is recognized as being present, the driver loads, everything looks like it should be working, but there is no RF signal. If we swap the functions of the radios around, whichever is using the top slot fails to work. The center and bottom slot work fine. We have tried this on several RB433 and they all behave the same.
We need to use kernel 3.2.5 because of some other drivers we are using and we cannot use ROS as they do not support the LTE modem we have to use.
I know this is an OpenWRT issue, but it is also all Mikrotik hardware and it seems like it is a hardware issue. Is there a problem with power to the top slot or something like that which would prevent the radio from working? PCI card sense? any ideas?
PCI sees it:
lspci
00:12.0 Ethernet controller: Atheros Communications Inc. AR5413/AR5414 Wireless Network Adapter [AR5006X(S) 802.11abg] (rev 01)
00:14.0 Ethernet controller: Atheros Communications Inc. AR5413/AR5414 Wireless Network Adapter [AR5006X(S) 802.11abg] (rev 01)
Logs don't show any problem:
dmesg | grep ath5k
[ 24.580000] ath5k 0000:00:12.0: registered as 'phy0'
[ 25.250000] ath5k phy0: Atheros AR5414 chip found (MAC: 0xa5, PHY: 0x61)
[ 25.260000] ath5k 0000:00:14.0: registered as 'phy1'
[ 26.000000] ath5k phy1: Atheros AR5414 chip found (MAC: 0xa5, PHY: 0x61)
iwconfig looks good
iwconfig
wlan1 IEEE 802.11abg ESSID:"GERMesh"
Mode:Ad-Hoc Frequency:5.825 GHz Cell: 16:51:08:FA:77:53
Tx-Power=24 dBm
RTS thr=2346 B Fragment thr=2346 B
Encryption key:off
Power Management:on
wlan0 IEEE 802.11abg Mode:Master Frequency:2.412 GHz Tx-Power=24 dBm
Power Management:off
mon.wlan0 IEEE 802.11abg Mode:Monitor Frequency:2.412 GHz Tx-Power=24 dBm
Power Management:on
The kernel modules are all there. I tried disabling ath9k by both building without it and black listing it, but that made no difference.
lsmod | grep ath
ath9k 88800 0
ath9k_common 1152 1 ath9k
ath9k_hw 347408 2 ath9k,ath9k_common
ath5k 146704 0
ath 14112 4 ath9k,ath9k_common,ath9k_hw,ath5k
mac80211 233312 2 ath9k,ath5k
cfg80211 134336 4 ath9k,ath5k,ath,mac80211
iw info shows the cards
iw phy0 info
Wiphy phy0
Band 1:
Frequencies:
* 2412 MHz [1] (30.0 dBm)
* 2417 MHz [2] (30.0 dBm)
* 2422 MHz [3] (30.0 dBm)
* 2427 MHz [4] (30.0 dBm)
* 2432 MHz [5] (30.0 dBm)
* 2437 MHz [6] (30.0 dBm)
* 2442 MHz [7] (30.0 dBm)
* 2447 MHz [8] (30.0 dBm)
* 2452 MHz [9] (30.0 dBm)
* 2457 MHz [10] (30.0 dBm)
* 2462 MHz [11] (30.0 dBm)
* 2467 MHz [12] (disabled)
* 2472 MHz [13] (disabled)
* 2484 MHz [14] (disabled)
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Band 2:
Frequencies:
* 5040 MHz [8] (disabled)
* 5060 MHz [12] (disabled)
* 5080 MHz [16] (disabled)
* 5180 MHz [36] (30.0 dBm)
* 5200 MHz [40] (30.0 dBm)
* 5220 MHz [44] (30.0 dBm)
* 5240 MHz [48] (30.0 dBm)
* 5260 MHz [52] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5280 MHz [56] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5300 MHz [60] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5320 MHz [64] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5500 MHz [100] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5520 MHz [104] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5540 MHz [108] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5560 MHz [112] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5580 MHz [116] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5600 MHz [120] (disabled)
* 5620 MHz [124] (disabled)
* 5640 MHz [128] (disabled)
* 5660 MHz [132] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5680 MHz [136] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5700 MHz [140] (30.0 dBm) (passive scanning, no IBSS, radar detection)
* 5745 MHz [149] (30.0 dBm)
* 5765 MHz [153] (30.0 dBm)
* 5785 MHz [157] (30.0 dBm)
* 5805 MHz [161] (30.0 dBm)
* 5825 MHz [165] (30.0 dBm)
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
max # scan SSIDs: 4
max scan IEs length: 2285 bytes
Fragmentation threshold: 2346
RTS threshold: 2346
Coverage class: 3 (up to 1350m)
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP (00-0f-ac:4)
Available Antennas: TX 0x3 RX 0x3
Configured Antennas: TX 0x3 RX 0x3
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
software interface modes (can always be added):
* AP/VLAN
* monitor
interface combinations are not supported
Supported commands:
* new_interface
* set_interface
* new_key
* new_beacon
* new_station
* new_mpath
* set_mesh_params
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* set_tx_bitrate_mask
* action
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* set_wds_peer
* Unknown command (84)
* Unknown command (87)
* Unknown command (85)
* connect
* disconnect
Supported TX frame types:
* IBSS: 0x0000 0x0010 0x0020 0x0030 0x0040 0x0050 0x0060 0x0070 0x0080 0x0090 0x00a0 0x00b0 0x00c0 0x00d0 0x00e0 0x00f0
* managed: 0x0000 0x0010 0x0020 0x0030 0x0040 0x0050 0x0060 0x0070 0x0080 0x0090 0x00a0 0x00b0 0x00c0 0x00d0 0x00e0 0x00f0
* AP: 0x0000 0x0010 0x0020 0x0030 0x0040 0x0050 0x0060 0x0070 0x0080 0x0090 0x00a0 0x00b0 0x00c0 0x00d0 0x00e0 0x00f0
* AP/VLAN: 0x0000 0x0010 0x0020 0x0030 0x0040 0x0050 0x0060 0x0070 0x0080 0x0090 0x00a0 0x00b0 0x00c0 0x00d0 0x00e0 0x00f0
* mesh point: 0x0000 0x0010 0x0020 0x0030 0x0040 0x0050 0x0060 0x0070 0x0080 0x0090 0x00a0 0x00b0 0x00c0 0x00d0 0x00e0 0x00f0
* P2P-client: 0x0000 0x0010 0x0020 0x0030 0x0040 0x0050 0x0060 0x0070 0x0080 0x0090 0x00a0 0x00b0 0x00c0 0x00d0 0x00e0 0x00f0
* P2P-GO: 0x0000 0x0010 0x0020 0x0030 0x0040 0x0050 0x0060 0x0070 0x0080 0x0090 0x00a0 0x00b0 0x00c0 0x00d0 0x00e0 0x00f0
Supported RX frame types:
* IBSS: 0x00d0
* managed: 0x0040 0x00d0
* AP: 0x0000 0x0020 0x0040 0x00a0 0x00b0 0x00c0 0x00d0
* AP/VLAN: 0x0000 0x0020 0x0040 0x00a0 0x00b0 0x00c0 0x00d0
* mesh point: 0x00b0 0x00c0 0x00d0
* P2P-client: 0x0040 0x00d0
* P2P-GO: 0x0000 0x0020 0x0040 0x00a0 0x00b0 0x00c0 0x00d0
Device supports RSN-IBSS.
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
Device supports HT-IBSS.
iw phy1 info
Wiphy phy1
Band 1:
Frequencies:
Bitrates (non-HT):
* 1.0 Mbps
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Band 2:
Frequencies:
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
max # scan SSIDs: 4
RTS threshold: 2346
Supported Ciphers:
* TKIP (00-0f-ac:2)
* CCMP (00-0f-ac:4)
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
* AP/VLAN
* monitor
Supported commands:
* new_interface
* set_interface
* new_key
* new_beacon
* new_station
* new_mpath
* set_mesh_params
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* action
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* set_wds_peer
* connect
* disconnect
* IBSS: 0x00d0
WOOF BANG!
DogHead
Re: RB433UAH w/RB52H miniPCI slot problem
Wed Oct 03, 2012 8:17 am
Could this be a power problem? Does the top slot of the RB433 get enough power to drive the RF amp of the RB52H when there are two modules used?
This is about the only thing I can think of.
WOOF BANG!
duvi
Wed Oct 03, 2012 12:59 pm
I've already posted about this in the OpenWRT forum.
This problem has been present in the same configuration since OpenWRT switched to linux kernel 3.x, so this is a bug in OpenWRT.
DogHead
Thu Oct 04, 2012 11:49 pm
I created a trouble ticket on dev.openwrt.org of Ticket #12269 on this topic.
It seems to be something related to PCI bus I am guessing. Not power as we have measured power under load and it is no different from top to bottom slot.
Any support on this would be helpful.
WOOF BANG!
Users browsing this forum: No registered users and 38 guests
