gnuttisch
OmniTik 750m to SXT whit bad ccq.
Mon Oct 15, 2012 11:10 am
Hi
Have a omnitik running in 5.21 to a SXT about 750m away.
Signal is about 69/66 and ccq 35/65.
I am the only one in the site so their is no interference.
Tx-power is set to default and iam running nv2 whit tdma set to 2ms and distance 10km.
Isnt the omnitik better then this ? do I have to set up a better mimo omniantenna?
any tips?
normis
Re: OmniTik 750m to SXT whit bad ccq.
Mon Oct 15, 2012 11:38 am
What do you consider "Bad" CCQ? did you look when traffic is running, or idle? This is important, as CCQ will change depending on traffic amount.
gnuttisch
Mon Oct 15, 2012 11:51 am
Hi
ccq is about 65/70 whitout any load.
When I run a bt test or torrent file the ccq drops to about 35/54. Isnt that bad ccq? I used to about 80-90-100 ccq.
normis
Mon Oct 15, 2012 11:59 am
Please make a supout.rif file at the time when you run traffic, we will see if the problem is with config, or with environment.
gnuttisch
Mon Oct 15, 2012 12:55 pm
I have sent one supout file to support.
I have two other links in the same tower, in freq. 5220, 5320 and the omnitik at 5745.
the picture is taken from the tower where the omnitik is mounted.
gnuttisch
Tue Oct 16, 2012 5:46 pm
I got a serious answer from Mikrotik.
the configuration looks ok.
You can try to change the wireless frequency, maybe it is saturated and you can't get the max speed.
But still 60Mbps is good speed and 90Mbps data-rate is good enough.
The conclusion is then that the OmniTik isn't bettern then this if I want to push out 30Mbit of TCP data to clients.
InoX
Tue Oct 16, 2012 9:53 pm
Everyone (almost) knows that Omnitik is very weak(small gain antenna) and will not go very far or very fast. :D
gnuttisch
Tue Oct 16, 2012 10:54 pm
Well, I know it now =) hoped that it would work perfect at 1km at least?
InoX
Wed Oct 17, 2012 12:12 am
1km is max. you can use at a decent signal and not maximum speed.
btw you should try 5300-5600 and see what is happening.
gnuttisch
Wed Oct 17, 2012 12:41 am
I have already bought ubiquiti mimo 2x2 omni antenna whit rocketik. I will mount a 711G-5hnd and try it out again.
I hope that my reseller would by my omnitiks back.
gnuttisch
Sat Oct 27, 2012 7:33 pm
I upgraded whit a ubiquiti antenna and a rf-element box. running a 711G-5HnD card.
the ccq doubled in my issue, now I have about 60-70ccq in load instead of about 30.
ugn
Sun Oct 28, 2012 2:28 pm
gnuttisch: Can you post a link to that 711 case/box you use there? :)
InoX
Sun Oct 28, 2012 2:50 pm
How hard is to search for rocketik?
gnuttisch
Sun Oct 28, 2012 4:21 pm
Yes, it's a rocketik.
ManyX
Wed Oct 31, 2012 9:21 pm
ddd
Thu Nov 01, 2012 12:10 am
Did you do a spectrum scan to see if there was interference on the channel you were using?
You should be able to achieve good speeds up to 3-5km proving there is no other usage on your channel.
gnuttisch
Thu Nov 01, 2012 4:41 pm
If read at top I wrote that I'm the only one in the site. their for I can plan the frequencies.
ddd
Thu Nov 01, 2012 11:25 pm
The Omnitik has a omni antenna - It will pick up interference from everywhere. You need to make sure you have a selected a clean frequency.
gnuttisch
Fri Nov 02, 2012 9:27 am
Yes, I have already check that. The site runs much better now when I changed the antenna.
brainy
Mon Nov 05, 2012 12:11 pm
Try to disable MCS 13,14,15
i have several installations where disabling them gives ccq of 100% .. with using them the ccq is going from 30 to 80%
nmthaker
Wed Feb 20, 2013 9:12 am
Hello
I disabled the MCS but the performance is not much stable yet, can any one advice how can i make more stable performance, the CCQ is yet 65/66 or 34/35 , 36/42 , 51/52, 67/11 , 61/73 ,
There are 10 CPE Connected with Omnitek.
Nishit
hipro5
Wed Feb 20, 2013 12:57 pm
This is one of the WORST antenna instalations I have ever seen..... :(
Haven't ANYONE out there ever told you that you MUST NOT have antennas THAT CLOSE together?
Try to intall one of them on another bracket/mast OR find another way to seperate them.
ALSO the collinerar enclosed omni antenna MUST be FULLY over/outside the mast/tower.
gnuttisch
Wed Feb 20, 2013 1:09 pm
hahahaha dude calm down...
do you see any cable to the omnitik? this is only a reference picture I took for my self that displays the differences between them.
I mounted the omni from ubiquiti moved the cable from the omnitik, took a picture. The removed the omnitik. then moved the new omni at the TOP of the "mast". If you had read the tread you have noticed that I replaced the omnitik whit the omni from ubiquiti.
hipro5
Wed Feb 20, 2013 1:15 pm
Ohhh.........shi(f)t!.........Thank you....... :D
jtroybailey
Wed Feb 20, 2013 1:48 pm
i would be more worried more about how the RJ45 is terminated
gnuttisch
Wed Feb 20, 2013 1:57 pm
:wink:
gnuttisch
Wed Feb 20, 2013 2:00 pm
how come?
the black shield is of about 1,5 cm but the twinning of the pairs are the same. The lid covers it very well. The RJ45 sockets is made fore solid cu.
how should you have done?
Users browsing this forum: Bing [Bot] and 35 guests
