ManyX
Omnitik problems
Mon Nov 05, 2012 11:57 am
What's your uptime on Omnitik?
I have very often watchdog reboot.
I noticed that the CPU use flash in /system profile is 100%.
I notice that sometime my other Omnitik cpu use 100% and watchdog reset it.
I notice alsow that winbox can't login to omnitik.
On one channel TX power fell down from -55 dbm to -88 dbm
Recently wirelesslan interface disappeared
Do you do you have also such problems?
brainy
Re: Omnitik problems
Mon Nov 05, 2012 12:08 pm
This sounds like hardwareproblem. You should RMA it.
ManyX
Mon Nov 05, 2012 1:08 pm
hardware problems? in 10 Omnitiks?
7 Omnitiks bought at different times?
3 Omnitiks I have changed to new one
All Omnitiks I have 10 pieces
Lakis
Forum Veteran
Forum Veteran
Mon Nov 05, 2012 8:17 pm
hardware problems? in 10 Omnitiks? :)
u must be unlucky
Dude dont worry there must be something u doing wrong
I never had problem with Omnitik -OmniTIK U-5HnD
but if its OmniTIK UPA-5HnD with PoE output I dont know. (never tried)
I read somewhere on this forum that they have same problems like u describe but its all now fixed
just upgrade to last Mt ver. and last firmware
watchdog reboot- can be due long time CPU usage=100%
if CPU is 100% its almost impossible to log in with winbox
wireless-lan can dispirited if the board (himself) is preparing to reboot (watchdog reboot) but it take a lot of time due CPU usage=100%
upgrade to last ver. 5.21,send ur config.
and send supout.rif to suport@mikrotik.com
ManyX
Mon Nov 12, 2012 12:56 pm
Another problem with Omnitik
This time without wlan interface :lol:
ManyX
Tue Nov 13, 2012 3:32 am
Omnitik has big problem with flash
CPU is usage 100% by flash process and after that is reboot by watchdog
that why Omnitik has a lot of reboot and hungup for a few seconds
Miktotik support do not want to admit to the problem.
I have a lot of screenshot and film on youtube with that problem
Recently I even try ROS 6.0rc3 but the problem occurs even more.
Omnitik hardware is completely unstable poorly designed and brooken.
druytssa
Omnitik problems
Sat Jan 19, 2013 7:31 pm
Hi have exactly the same flash and reset problem with my Omnitk. I have lots of angry customers and think of taking out the unit and putting in Ruckus. No solution from support so far.
karina
Tue May 07, 2013 1:03 pm
I have several Omnitiks that are randomly rebooting every 2 or 3 days Ros v5.24, simple AP bridges 4 or 5 clients. I see from posts that I am not alone. Has anybody found a fix for these yet. or are they simply not stable enough for a production enviroment. Can Mikrotik shed any light on this one
fresnel
Fri Feb 14, 2014 5:40 am
I have just experience the exact same issue. The OmniTik reboots and comes back without a wlan1 interface! What can be done to fix this? I'm running 6.9. Is downgrading recommended?
-J
plisken
Fri Feb 14, 2014 9:17 am
Try install routeros 6.7 with netinstall and try again.
The omnitiks that I have (5) are stable and work excellent.
I use 27 volt PSU of meanwell.
The omnitiks were not stable with 12 volt power supplies
Petzl
Mon Feb 17, 2014 1:47 am
We have 100 stable omnitiks in the field
only the one at my home has wireless that stops working.
If you have TX - RX problems , then you have to check the antenna connections, i had one with a short cirquit and one with a missing solder point ...
Users browsing this forum: No registered users and 16 guests
